Window Valet Problem
Old Dec 15, 2015 | 01:30 PM
scoy100's Avatar
scoy100
8th Gear
Default Window Valet Problem
When pushing the lock key fob button three times to close the windows, the windows go up, then the horn honks three times and the windows go back down. After multiple times of pushing the lock key fob button three times, the windows finally stay up. Has anyone experienced this problem and does anyone have a cure to the problem? Thanks
Old Dec 15, 2015 | 01:44 PM
RVETTE42's Avatar
RVETTE42
I have this problem also. If door is open it works fine. If door is closed mine dose the same thing and there is nothing in its path and both windows starts out all the way down.
Old Dec 15, 2015 | 02:18 PM
Phanni's Avatar
Phanni
Try resetting the window up limit.
simply turn on ignition and then push the up button and hold it for about 5 seconds.
Do both sides
Old Dec 15, 2015 | 02:33 PM
rrwirsi's Avatar
rrwirsi
When I first installed the Valet, it did the same thing. I removed the device and waited a few minutes. Inserted the device again and did the learning mode following instructions. Then it worked. Hopefully it will work for you.
Old Dec 15, 2015 | 03:23 PM
scoy100's Avatar
scoy100
8th Gear
simply turn on ignition and then push the up button and hold it for about 5 seconds..
Do both sides
Thanks I will this a try when I get home
Old Dec 16, 2015 | 08:22 PM
scoy100's Avatar
scoy100
8th Gear
I did the resetting the window up limit by simply turning on ignition and then pushed the up button and held it for about 5 seconds. First on the drivers window and then the passenger window.
It worked perfectly.......thanks.
Old Dec 16, 2015 | 08:28 PM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
I wish I could get it to work with my aftermarket alarm FOB
Old Dec 17, 2015 | 01:03 AM
Z06 Zephyr's Avatar
Z06 Zephyr
Somebody beat me to it but yes, a simple limit reset works just fine. Mine did the same. I love my valet
Old May 26, 2016 | 05:18 PM
sloopdawg's Avatar
sloopdawg
Just got my valet and love it too
Stupid question....
Do I remove the thing-a-ma-jig that's in the OBD2?
I read the instructions but dosen't say whither or not to remove it after configuration
Old May 26, 2016 | 05:58 PM
Phanni's Avatar
Phanni
Stupid question....
what is in the OBD2 port?
You simply plug in the widow valet as nothing should be there already.
If something is already there, it is probable another window valet that is left over from another owner. Then you follow the programing (validation) procedure.
Old May 26, 2016 | 06:12 PM
sloopdawg's Avatar
sloopdawg
the valet thing is in the obd2 port right now
i programmed according to instructions (works flawlessly)
can i remove the valet thing or do i leave it in?
the instructions do not say to leave in or remove after programming
Old May 26, 2016 | 09:17 PM
sloopdawg's Avatar
sloopdawg
E-Mailed Top Down and they said for it to work you have to leave it in. You can remove it if you need to use the OBD2 but you have to reinsert it if you want to use the features. So good to know. Feel kinda' stupid like I should have known but like I said before, the Instructions don't specify one way or the other.
A cool product that I can see being useful to me.
Old May 28, 2016 | 01:33 PM
Caveboy's Avatar
Caveboy
Only if they work with an aftermarket remote!😢
To Window Valet Problem
