Jacking up a c5
that was so easy to do on the C3 jack in the middle and pop in two jack stands and move to the other side. up in air in 8 minutes
i also have a set of race ramps that i used on my c4 for changing the oil and to get underneath the front.
i was looking at doing c5 oil changes and it looks like i need to put the front on the ramps, and then jack up the back to level it out so the oil will drain. i was wondering how i will be able to do that.
i have 1 jack and 2 jack stands.
thanks for the diagram. ill have to study it and get my car on the ramps to take a look under it.
it looks like you use back ramps as well? do you ramp up all 4 wheels at once?
i only have the 2 piece style front ramps because i never needed to get the back of my c4 off the ground.
c5 are more complicated i think!!
