[Z06] Factory freak? Numbers inside...
Old Dec 19, 2015 | 07:34 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Default Factory freak? Numbers inside...
'03 Z06 with 33K miles
Only mods are Airaid Filter, GHL Bullets Catback and RPM motors Dyno Tune.
395.7/385.9 SAE
I recently added the Airaid filter and after some miles, my car threw lean codes on both banks. All clamps were tight, so I disconnected the battery. Drove another 100 miles and no CEL, but LTFT's were still way off at 20% @ WOT. Decided to get a dyno tune and put out these freakish numbers. Tuner said it's very rare he sees these high of numbers with my mods. They're in range with the addition of LT's.
Although Airaid claims no tune needed with this filter, I wouldn't run it without a tune. Way too lean.
Old Dec 19, 2015 | 08:32 PM
bartsky's Avatar
bartsky
Sounds like Dr FrankenZ!!! Yea those are amazing numbers without longtubes...
Old Dec 19, 2015 | 08:37 PM
95wht6spd's Avatar
95wht6spd
I would guess something is off with the dyno, modern cars don't have much variance from the factory. Those numbers are around what other get with LTs and a small cam. The HP is high, but the TQ even more so IMO. As long as it is no longer lean, and runs well, that is the main thing.
Old Dec 19, 2015 | 08:39 PM
03 Z-oh-6's Avatar
03 Z-oh-6
I'm going to dyno somewhere else to compare. It's a very reputable shop where it was tuned. LTFT's are much better now.
Old Dec 19, 2015 | 09:26 PM
Verrückt ZR1's Avatar
Verrückt ZR1
I've been meaning to do the exact same thing. When I had my car dynoed in April/May, the numbers seemed too good to be true. '04 Z06, Blackwing intake, LG Super Pro longtubes, and tune. The car made 429.*/386.* rwhp/(ft/lbs) respectively. Numbers are way off IMO, but everyone I've spoken to in town swears by the tuners work. I'm going to have a couple of dyno pulls done when it warms up a touch, and get some more accurate readings for my own peace of mind. In any case, great numbers!
Old Dec 20, 2015 | 05:32 AM
Ferg03 Z06's Avatar
Ferg03 Z06
As long as the car runs how it should then you should be fine. The numbers are definitely high for the "norm".
There is a correction factor that can be added to the dyno to increase numbers. It sounds like to me that the correction is set to high.
Cammed guys with stock 243's and stock LS6 intakes only make ~425 give or take a few HP based on the cam they chose. I have a rather large cam with a .621 lift with mid 230 duration. I only made 439/417 on a dynojet. With LT's and a vararam, so something is definitely off with the numbers.
Old Dec 20, 2015 | 09:54 AM
03 Z-oh-6's Avatar
03 Z-oh-6
FWIW, the baseline run before the tune, my car hit 390/375 SAE. He said the computer had been altered before(bought the car used), but just the fan settings and speed limiter were changed; everything else looked stock. So, there was not a ton of power picked up from the tune, he just fixed the lean condition and a few other things.
Old Dec 20, 2015 | 10:01 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I hit 430 rwhp/390 rwtq with cam, ARH lt's and atune with a 346 and stock ls6 intake. I'd be interested in the other shops readings
Old Dec 21, 2015 | 12:21 AM
Verrückt ZR1
I should just cam the car and then the numbers would be legit. Very tempting.
Old Dec 21, 2015 | 07:13 AM
03 Z-oh-6's Avatar
03 Z-oh-6
I'm definitely going to take it to another dyno. However, I'm adding different wheels/tires which should add about 7 pounds per side in the rear. Not sure how much difference that will make with the numbers.
Old Dec 21, 2015 | 01:24 PM
Breze84's Avatar
Breze84
As long as you have 1/4 mile times and traps to support those numbers for the legitimacy and accuracy of those power numbers you are gold and have something special. But if not, Numbers are just numbers and the realization of it is all dynos read different and i have seen some VERY happy dynos... I have personally seen a friends car dyno 415/395 on 1 dyno at a open house and dyno 396/379 on another shops. Both Dynojets...
Old Dec 21, 2015 | 04:34 PM
95wht6spd's Avatar
95wht6spd
Are you sure nothing else was done to the car when you purchased it?
Verrückt ZR1
Nothing that I know of. Anything is possible though.
Old Dec 21, 2015 | 11:49 PM
dagon138's Avatar
dagon138
Go try another dyno and see if you get similar results. I've seen similar numbers before on here for stock C5 Z06's from that shop's dyno actually. It could be that that type of dyno reads higher than mustang and even dynoJet.
Still they could be that aggressive of a tune...they did/do a lot tune for the local LSx T1-spec race cars so hard to say...
I've got some nice dyno plot's from RPM too.
Old Dec 22, 2015 | 08:10 AM
robz's Avatar
robz
For a drag strip comparo:
With 396hp/ 35Xtq years ago we trapped 124+mph in good air with 3.90 gears and a relatively heavy drag pack with no weight removal.
Old Dec 22, 2015 | 09:00 AM
03 Z-oh-6's Avatar
03 Z-oh-6
Going to superior Automotive to dyno to compare. They use a dynojet, I think. I wouldn't be shocked to see lower numbers.
The guys who tuned my car really know what they're doing, however.
Old Dec 24, 2015 | 12:35 PM
Kins13y's Avatar
Kins13y
Although I do admit your numbers are pretty high for no longtubes, anyone making sub 400 with an aftermarket cam needs to go back to the drawing board.
To Factory freak? Numbers inside...
