Maintain idle
Old Dec 22, 2015 | 12:18 PM
wmjosjr's Avatar
wmjosjr
Default Maintain idle
I have a 2004 Z06, Stock heads, Worked, cam swap, 92 Fast intake, LS2 T/B etc. I had a Dyno Tune done. after that I had a sporadic idle, and a difficult time to keep it from stalling. went back to the tuner and explained the problem I was having. I did notice my idle was just below 800 (RPM). Coming to a stop My idle would drop below 500 RPM, and go into a stall if I didn't feed gas. This was not an issue prior to the tune I had before. When I asked him to bring the idle up to 900 rpm It helped, and the issue got a little better . But not totally. The tune itself is responsive and snappy, that part I am pleased with. Any help would be greatly appreciated.
Merry Christmas and a happy New Year to one and all.
Bill
Old Dec 22, 2015 | 05:55 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Have you tried spraying your TB and MAF....could of gotten dirty or maybe right on the edge of dirty or even damp...
mike v
Old Dec 22, 2015 | 07:15 PM
onspeed's Avatar
onspeed
Did the tuner just run it on the dyno a couple times?
Old Dec 22, 2015 | 07:23 PM
wmjosjr's Avatar
wmjosjr
mike v
Will do.
Thank you.
Old Dec 22, 2015 | 07:28 PM
wmjosjr's Avatar
wmjosjr
yes to your question. He also drove the car. I was thinking maybe a bump up to a little over 900 RPMS might do it.
Thank you.
Old Dec 23, 2015 | 01:27 PM
enoniam's Avatar
enoniam
You should ask the tuner if he increased the idle air flow. Car has short and long idle air flow trims that change to get to the set idle rpms. Long term trims are usually somewhat limited. Your car may need 50% or more air flow to idle nicely.
Old Dec 23, 2015 | 05:36 PM
wmjosjr's Avatar
wmjosjr
Great advice, will do.
Thank you.
To Maintain idle
