[Z06] I have a weird problem? ?
Old Dec 23, 2015 | 08:43 PM
04zjimc's Avatar
04zjimc
Default I have a weird problem? ?
Installed a complete stereo system wires, amp, speakers, radio. The problem is I use a battery maintainer..since the install I can't get the green light to come on tell me it's charged? The light stays in the yellow tell me it's still charging. If I take the Amp power wire off the green light will come on wtf?
Old Dec 23, 2015 | 11:52 PM
CalF's Avatar
CalF
#1 Check battery condition.
#2 Amp needs a switched connection or install a relay to shut amp down to prevent parasitic drain.
Depending on the size of the amp it may be drawing more than your tender can replace.
Old Dec 24, 2015 | 01:16 AM
04zjimc's Avatar
04zjimc
it's drawing power when the car is off?
Old Dec 24, 2015 | 10:34 AM
CalF's Avatar
CalF
Yes the amp will draw power if wired to an unswitched power source.
Old Dec 24, 2015 | 04:48 PM
Dan Z06's Avatar
Dan Z06
Sounds like CalF is on the right path you have an extreme draw when the car sits. Take a voltage meter to the ends of the battery charger to see what it's putting out (just to make sure your tender/charger is working correctly)
Old Dec 24, 2015 | 05:16 PM
04zjimc's Avatar
04zjimc
I wil check but everything was fine till I hooked u this system.
Old Dec 24, 2015 | 10:35 PM
CalF's Avatar
CalF
Did you use an Amp remote wire to head unit?
Old Dec 24, 2015 | 11:01 PM
04zjimc's Avatar
04zjimc
Yes I did blue and white wire. Ok everything is fine battery just needed alittle more time to charge.
To I have a weird problem? ?
