Esser's 2002 M6 Coupe Progress Thread
I am also in the process of having the front of my driveway leveled to the street. As you all probably know a lowered vette has a lot of trouble with curbs, so I had mine completely removed lol. It now has a smooth transition to the street. I shouldn't have to worry about getting in and out of the driveway anymore!
They tore it all out and redid it:
While that was going on I have started the paint correction process! I am still taking some pictures for that, will update tomorrow.
Great to get the small issues out of the way if they bug you. I bought my vet from a owner like you and have had no issues other then the classic window reg and tail light issue.
No good! My goal will be the 100% swirl elimination and a complete paint correction. While a bunch of people do detail jobs, I'm going the extra length on this one lol. Everyone has there own methods of washing and polishing and waxing etc, I will be showing you the method I use to create a great shine. I can honestly say that I challenge anyone to find imperfections in my paint when I'm done. The price for materials is not expensive, it just takes time and patience to get the perfect finish.
This is my process that I developed through a lot of trial and testing. I have found that there are a few instances when the high dollar products are simply overkill, and off the shelf items are perfectly fine. There are, however, several cases where the high dollar products are worlds ahead of anything you will be able to buy at the store.
First step in the process is to rid the paint of any previous wax or deposits. The wash and clay is always the first step. For a wash I use a microfiber hand mit and a grit guard bucket. The grit guard prevent any of the dirt and containments from diluting the wash water and going right back into the paint. My soap combination for this is a 50/50 mixture of dye free dawn dish soap and any light car wash soap. The dawn has some detergents and degreasers in it that will strip the wax from the paint.
Big point here is to do this on a sunless day. Cloudy warm days are the best car wash days! I hate getting water spots on fresh paint.
No extreme science here, wheels and tires first with a seperate rag. Then work from top to bottom. After the car is washed dry immediately and then bring it under cover. I always finish the drying process with a microfiber towel in the garage
After its in the garage and dry, I go ahead and start the clay bar process. I use a pinnacle poly clay bar and "wet" water. Wet water is just a mixture is isopropyl alcohol, water, and a drop of liquid soap. I just filled up the old pinnacle clay lubricant spray bottle with this solution with the same results.
I take one of the bars and make it into a pancake and rub. No science here either, just try to to press with your fingers, more your palm so you get the most surface area of force on the paint. I run until it glides smooth. I do the whole car.
And the girlfriend wanted to help out a little with the clay bar:
After each panel is done, wipe with a clean microfiber. I usually glide my hand over to make sure the surface is smooth after. Anything that is not smooth will tear up your polishing pad in the next steps. To be continued in the next post!
Now that everything is masked off, I do a isopropyl alcohol wipe on all the paint surface to prepare it for the cutting. You want to rid the paint of any dust or particles that may have fallen on it while sitting. You don't want to rub in more abrasives to the paint than needed. I make a mixture of half distiller water and 90% isopropyl alcohol. A light mist and a wipe with a microfiber is plenty.
For the cutting of the paint, I like to use Wolfgang total swirl remover and an orange CCS pad on my Porter Cable. The orange pad is fairly abrasive and should take out most swirls in the paint. The Wolfgang polish is really a necessity for this step, it is the perfect amount of abrasive for removing very light swirls. The orange pad compliments it well. For lighter swirls a white pad is fine to use.
Make sure to mask off the portion of paint you are working on. I sudoku mask off an area about 1x2 feet. This helps you keep track of where you are and doesn't let you get too far out of the range of compound for one pad.
Apply a light amount of compound and spread across the panel. For the cutting I turn the porter cable to a speed of 5.5 and apply enough force on the paint to keep the pad rotating at 1 Revolution per Second. No more and no less.
I work on each masked off section for about 30 seconds going back and forth and side to side at a slow rate. Then wipe off and move on to the next section. Remember to overlap areas to ensure no paint is left untouched. Refill the pad with a light amount of compound between each section.
After its wiped away the paint will be smoother than you've ever felt, and will shine like it's been waxed, but it's bare paint! Make sure you wipe away all the compound. If it does not get all the swirls, you can repeat the steps on the same panel. For the C5 vette I have found that: the paint on the hood, roof, and rear bumper is soft, and the front and rear fenders, and front bumper are rock hard.
Continue working the sections until the problem areas are done. I did the entire car because the Wolfgang swirl polish is not that abrasive so I switch to a white pad for the panels that don't need much work.
It should be visible how much clearer the piant is at this point, and should give you some motivation to do the rest of the back breaking work!
The next step will be to glaze the paint.
I run the porter cable at about a speed of 4 and again try to get the pad to rotate at 1 revolution per second. I again went over the whole car again with the glaze. The girl helped a lot on this one!
Again repeat the same process as sectioning off a small section and wipe clean with a fresh microfiber after your done with the section. After the whole car is complete, it's time to clean up any left over glaze with an IPA wipe. I use my 50/50 mixture of water and isopropyl alcohol to wipe down the paint and get it back down the bare clearcoat. The sealant of choice that will be applied is the Wolfgang deep gloss paint sealant 3.0. It's simply the best sealant and can even be passed as a final wax for the shine it provides.
I use the blue pad for the sealant application. The blue of is super soft and doesn't do any type of cutting or polishing, it just glides over the paint and applies the sealant. I don't section off any of the pint for the sealant, just run the Porter cable at a speed of 3 and let it do all the work. You don't need to press down on the pad at all, let the weight of the Porter cable apply its own pressure. I cover the whole car in about 15 minutes, covering each section 2-3 times with a fresh pad of product.
Once the sealant is covered over the entire vehicle, it must be left to dry for at least 40 minutes. I usually let it sit for about an hour and then come back to wipe it all off.
After it has set I come back with a wool cloth and remove the surface of dry sealant. It should come off super easy and have very minimal dusting. The before and after of the wipe down will blow you away.
The shine that the deep gloss sealant provides is really unmatched. At this point you must let the sealant sit for 12 hours without getting any moisture on it to completely dry. I let it sit in the garage overnight and come out and give it another wipe down to get any dust off.
The first coat of sealant will be super glossy, but a second coat of the super gloss sealant will really give the paint an extreme depth.
The paint is slick and glossy. Its hard to get a good picture of the gloss, as the sun picks up the affect better than natural light. It has been rainy here for the last few days so I will get pictures when it clears up.
I have to let my driveway cure for at least 7 days before I can drive on it. It doesn't help that it's cold and rainy outside so the concrete is staying damp and slowing down the curing process.
Wash with Dawn
Clay bar
Wash again
Ipa wash
3m perfect it compound with orange pad
V36 w orange pad
Ipa wash
V36 with white pad
V38 with white pad
Ipa wash
Cg black light 2 coats
2 coats Pete's 53 wax
1 coat of v7 QD
Wash with Dawn
Clay bar
Wash again
Ipa wash
V36 w orange pad
Ipa wash
V36 with white pad
V38 with white pad
Ipa wash
1 coat of v7 QD
Sounds like a solid setup. I used to have a very similar process with varying compounds and brands, but the formula is sound. And to answer your question about the wax... I won't be topping it with anything over the sealant. I used to always top off my sealant with wax, but after Wolfgang released this sealant I have never noticed a difference that was worth it. Even with a high dollar wax over the sealant, the result to me is not worth the price and I don't think it adds to the durability. I have just been sticking with the two coats of sealant, and it always shines the same until it wears off. This sealant is really hard to beat!
I do however apply a liquid gloss spray after the first wash. It's not considered a wax, but it does form a coat over the sealant, and does add a bit of gloss. I'll try to get some pictures in the sun this week if it ever comes out!
So when it comes to polishers, there are two distinct kinds: a normal rotary polisher which will spin a single rotation and a constant rpm, and then there is the dual action polisher (DA). The dual action actually has a clutch in it, so the settings on the polisher control the motor speed but don't affect the speed of the pad, just the force. It's hard to explain but if you press lightly or hard on a basic rotary it will try to spin the same rate. While with a DA polisher you can press down hard and actually stop the polisher from spinning completely, while the motor is still going. I adjust my speed level until I can use enough force to almost stop the polisher from spinning and slow it down to a 1 revolution per second. So to answer your question it would depend on what type of rotary tool you have.
It's easy to burn through paint with a normal rotary tool. The dual action is safer due to the clutch, and it will stop before you die any real damage. The dual action orbits in a circle while it spins, so it just appears to be vibrating if you were to hold it in the air or stop it completely against the paint.
I use the heat gun to let the wrap fall into the crevices and then use an exacto knife to trim away at it.
Love the attention to detail and step by step how to for the paint correction. Keep the posts coming! Car looks great.
