[Z06] Breathless Intake Horsepower
We expected it to add 15hp. We are thinking it might add more as the computer gets used to managing the addn'l air and the car breaks in. Otherwise I'm wondering if I should return it and do an exhaust which will at least sound better to boot.
reason is this
97-00 cars had NO hole in top of the airbox (**** poor breathing)
01 cars had a 2 to 3 inch hole in top of the airbox (better breathing)
02 up cars have a 7 inch hole in top of the airbox (even better breathing)
now, dont be disappointed with your gains........remember, you get RAM AIR when you drive and the faster you go, the more RAM ya get which means MORE HORSEPOWE :cheers:
thanks
[Modified by Ram Air Tony, 8:23 PM 8/29/2002]
The question is, was this a good way to spend $600. Perhaps a cam or exhaust is more valuable. At least the exhaust sounds good.
If you want sound, you can get an exhaust for that money. I think something like a cam is more complicated.
I think you had an S2000 before. The 02-03 Z06 is similar in that normal bolt ons don't give you much power.
[Modified by SilverZ06Chris, 8:57 PM 8/30/2002]
[Modified by SilverZ06Chris, 8:58 PM 8/30/2002]
[Modified by SilverZ06Chris, 9:05 PM 8/30/2002]
Carroll Smith in "Tune to Win", P. 106 says...
Intake Ram (psi) equals:
Air density (lb/ft^3) X (Air velocity in FPS)^2
288g
80 mph - Intake Ram =
.076 X (118)^2
------------------ = 0.11 PSI
288 X 32.2
BUT he ALSO ADDS
"In both cases we have assumed a 100% efficient duct, which is not possible---75% efficient would be a good one"
Turbulence isn't the real problem. In any piping run, a boundary layer builds up next to the wall where the flow velocity is actually zero. As the roughness of the pipe wall gets worse, the boundary layer grows thicker. As the air moves on down the pipe, it is slowed by the boundary layer effect (head loss) and the boundary layer essentially grows thicker slowing the air more. If the run is long enough, the head losses can actually be long enough to completely stop the flow (pressure differential between the inlet and outlet is zero).
Take the vent on your dryer and add about 30 feet to it and you'll see that
there's not enough pumping power (from the exhaust fan) to even move the air through the hose. The same head losses occur every time straight flow is interupted by a bend, valve, fitting, etc.
There's a piping engineer's bible published by Crane Valves (Technical Paper #410) that puts all the equations together and will let you calculated the pressure drop through a piping network with all the variables you could think of.
I got this off a Mustang list YEARS AGO when all the 5.0 guys were trying to do ram-air.
Here's a member's site that is very good at explaining this as well.
http://www.vetteguru.com/ramair
[Modified by Tom Steele, 3:27 PM 8/30/2002]
Thanks!
with ram air / cold air induction. I would say the avg mph gain
in the qtr is 2-3 mph. I don't see how anyone could dispute fresh cold air
to the intake vs under the hood hot air not being a factor.
I would bet the mph on a stock 03 Z06 with ram air would be
higher than a stock Z06 with exhaust, especially on a hot day.
J.P.
that is FACT :yesnod:
R
A
T
I'd like to at least make you think about it. First, the hot air under the hood - where is it coming from? When you are going 100mph, how static is it? It is not a closed system. As long as the air hasn't gone through the radiator/condensor first, or up by the headers, it shouldn't be obscenely hotter than the outside air when the car is moving at reasonable speeds.
It IS hotter, but not as much so as you might think.
Second, where are the cold air intakes getting their air? Right off the ground. Ever measured temps a foot off hot asphalt? I bet that air isn't as cold as you think.
All that aside, I don't doubt that the cold air intakes do offer some advantage in intake temps. I'd like to see more tests to see exactly how much.
But Ram-air is a myth!
On my '02 the Breathless Vortex Rammer intake made 1rwhp...and yes, it was installed right (by me). :(
However, after doing some datalogging with my EASE scan tool, I realized that my fuel trims were all screwed up. This made sense b/c the A/F ratio went from 10.8:1 over 4000rpm (stock) down to 10.2:1 after installing the Vortex.
I purchased a MAF Translator, got the fuel trims corrected, and without doing anything to the WOT fuel adjustment, this gave me 6rwhp on the dyno (like yours...so maybe your fuel trims are fine). I then leaned it out to ~12.4:1 A/F ratio and picked up another 7rwhp, for a total of 13rwhp. I was not disappointed in this. Sure I had to spend a little extra $$ to tune it right, but as others have pointed out...at a standstill, with very little ventilation, you are not going to get the _full effect_ (whether you believe in Ram Air or not) while you are stationary. If nothing else the Air Temperature will be higher when you're stationary and the computer at times will compensate for this. During my datalogs, the aftermarket airbox will consistently keep the air charge right at ambient once moving, while a stock airbox is typically 15-20^ higher, and when you're sitting there on the dyno with a small fan blowing in front of you, its still 15-20^ higher than ambient.
So it may just take a little tweaking. A camshaft is a good mod for these cars (even with stock heads) if you don't mind a lopey idle and the fact that it will not pass a roadside sniffer (saw one up at Hwy 121/Coit road the other day). But I know of guys who are ~400rwhp with no cats, long tube headers and a camshaft and NO headwork. That is impressive to me.
A cat-back system will sound great, but will not make enough power to warrant the purchase, IMHO. Anything that is not titanium is a compromise as far as power-production is concerned. You might pick up 5rwhp, but you'll also gain 30lbs. I would only purchase one of these for the sound. I like the way my '02 exhaust note sounds, but I'm getting older and don't care for something too obnoxious. :D
[Modified by WA 2 FST, 3:03 PM 8/31/2002]
R
A
T
You spent a lot of money!! I would take it back and get an intake system on here without a powerduct for $210-$250. Use that extra money you saved to help buy some long-tube headers and get them installed. I bought TPIS headers online here and had Speedworks install them. Made a VERY noticeable difference. Two more good mods are the CAGS defeat ($20) and a Hurst or Ripper Shifter ($150-180). :cheers:
