couple years back I installed the kit that would make all 4 headlights stay on ,on high beam ... they started to not work when only on low beams . they work as they should on high beam . Fuses look good . Could it possibly be the relay that was supplied have gone bad????TIA xzo
From: Wylie TX --> Less is More, except under the hood !
Yea the relay could easily be your issue. I would disconnect the relay, scuff up the connectors and re-connect. See if that helps to start.
I got a relay that I have setup to keep my FOG lights ON, when I turn on my high beams. It started flickering a month ago, and now its not keeping my FOG lights on at all when I go to high beams. I suspect I need to scuff up the connections, or I have a bad relay. They are cheap at Radio Shack, or Automotive store.
