2001 C5 6 Speed
Old Jan 18, 2016 | 07:16 PM
C5Colton's Avatar
C5Colton
1st Gear
Default 2001 C5 6 Speed
Hey y'all new to the forum, I've ran into a major issue with shifting. The car will not go into 1st 2nd or 4th. Extremely hard to shift. Clutch master fluid is clean as a whistle, can't tell if it's a clutch, synchros, or something else. Car is barley drivable and it's my DD. Please get back to me with some info asap. Anything helps. Thanks everyone.
Old Jan 18, 2016 | 11:44 PM
73Corvette's Avatar
73Corvette
Usually it is the clamp that connects the shifter box to the shaft that runs back to the trans... IT has to be adjusted almost perfectly to shift properly and IF there is ANY slipping or the bolt gets wore it will make it very hard to get into those gears...
Anti venom mod and Amsoil Torque Drive fluid along with the Ranger Method will all also help... BUT the biggest improvement will be a MGW, or some other aftermarket shifter OR you can get a C6 Z06 shifter and box and bolt it right in ... makes a HUGE difference.
In this pic you can see the clamp and torx head bolt at the end of the box...the gold color thingy is the clamp...
Old Jan 19, 2016 | 09:14 AM
kflohrit's Avatar
kflohrit
I just posted about a similar issue and was given the same advice. There are a couple photos and tips in here that might help.
https://www.corvetteforum.com/forums...ervice-m6.html
Old Jan 19, 2016 | 09:51 PM
ClipperFan's Avatar
ClipperFan
Change the trans oil too just because...........It made shifting on my C5 easier. Yours won't go into gear at all Good luck
To 2001 C5 6 Speed
