500rwhp Drivetrain Question
Thanks guys! I'll definitely do some upfront upgrades but it's nice to know I should be able to do this in stages.
,,,,,,,,,,, The second you open up and unleash that 500 RWHP on that basically stock drivetrain,,,, you will have problems and maybe some drive train breakage. Here is a list of parts that you will need to address WAY AHEAD OF TIME before FULL THROTTLE DAY!
- Engine Mounts! They will most likely NOT be happy! You will need new OEM or EXPENSIVE poly mounts!
- Transmission mount: Look for and install a PFADT style mount.
- Torque tube bearings and rubber couplers: The rubber couplers and TT bearings can and usually are near death. Pull the TT apart and examine the bearings and couplers. If the couplers are not like new, REPLACE them with GM OEM. If you are really going to race the car, contact ECS and talk to Doug or Chris and get their advanced TT components.
Trans /DIFF Brace I recommend the ECS Trans /DIFF brace. It a very nice piece!
Differential!! OH BOY!
Very WEAK LINK for that power range! Here are some post you need to study and some modifications you might want to undertake:-
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5, Its Go TIME, Differential Rebuild post: https://www.corvetteforum.com/forums...1&p=1591127325
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
If you have ANY wheel hop/drivetrain shake, you will most likely break an output shaft.
Your limited slip clutches and or Beleview spring are most likely not up to the task of that power level.
Transmission.. Good stuff to know: C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
CLUTCH! IT WILL NOT WORK with that power level. The clutch peddle will most likely stick to the floor under the very FIRST full throttle shift! You need one of the best clutches that you can find to have a trouble free transmission shift. You are looking at an easy $1000.-$1500 for a quality clutch and parts.
SHOCKS! YES! New "BETTER" shocks with proper dampening will HELP control drivetrain issues BUT, it is NOT the cure.
Hope this helps and your walled doesn't have a STROKE!
Bill
