New C5 Owner
Old Jan 24, 2016 | 02:29 AM
Not4spd's Avatar
Not4spd
Looks like lots of miles of smiles will be headed your way. Nice head turner you got there. Is this your second Vette, the first being the 96?
Old Jan 24, 2016 | 06:08 AM
Silverwolf_pup's Avatar
Silverwolf_pup
Congrats on the Corvette, she is a beauty I will never forget how i felt driving my dream car home. I felt like i was invincible.
Old Jan 24, 2016 | 06:20 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Looks good. How many miles on it?
Old Jan 24, 2016 | 06:38 AM
LannyL81's Avatar
LannyL81
Car had 28778 miles when it came off the truck and I added another 5 miles for the drive home and into the garage. I do not have title yet so it will stay in the garage until it arrives and then off to get emissions checked and then then to AZ MVD for Level 2 inspection and then finally for title and registration.
I will be doing the Ranger method on the clutch today. Brake fluid will be next, but need an assistant and have it on jackstands. Got to finish making the wood supports first.
This is actually my 5th Corvette: have had an '81, two '96 CE LT4s, one '95 and now this 2004, I still have a '96 and just sold the '81 on Jan 1. This is my first 'vert though, never liked driving with the targa roof panel off of any of the C4s I had....too much movement!!!
Guess I should go get busy, first thing is to take the battery and battery tray out and look for acid damage.
Going to have to do something about those stock mufflers though...waaaaaay to quiet!
See ya.
Old Jan 24, 2016 | 08:00 AM
jans's Avatar
jans
Now that is a nice delivery ! Enjoy and be safe.
Old Jan 24, 2016 | 10:49 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Congrats, picked my 99 up last weekend and now just waiting for spring
Old Jan 24, 2016 | 10:51 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Enjoy your new ride.
Old Jan 24, 2016 | 11:02 AM
Johnson 92's Avatar
Johnson 92
C5 of the Month 6/13
Congrats!!!
Old Jan 24, 2016 | 01:16 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Congratulations - One of my favorite color combos too
Old Jan 24, 2016 | 01:40 PM
doublenut9's Avatar
doublenut9
Welcome to the group! Car looks fantastic!
Old Jan 24, 2016 | 03:45 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Congrats and welcome!!! Looks great!!!
Old Jan 25, 2016 | 05:54 PM
c5z06.O's Avatar
c5z06.O
Default great
Great looking vette. Hope all ends well after. the fixes.
Old Jan 25, 2016 | 09:54 PM
  #33
lebeeby's Avatar
lebeeby
Let me add to the congrats....you'll love the 'vert. You'll wonder why you didn't get one sooner. Doesn't keep the fluffy rain out though here in MT.
Old Jan 25, 2016 | 10:11 PM
  #34
00Midnight's Avatar
00Midnight
Struts are easy to do. Pop them off...pop them on. I did mine by carefully using a flat blade screwdriver to remove the clips but this can also be done by leveraging them off as the clips are spring loaded. Suggestion: do the trunk ones at the same time.
Old Jan 25, 2016 | 10:45 PM
  #35
ZeeOh6vette's Avatar
ZeeOh6vette
Originally Posted by 4XLR8N
Nice! Welcome to the asylum...
You got that rite
Old Jan 26, 2016 | 08:41 PM
  #36
LannyL81's Avatar
LannyL81
Struts....I did not see any struts to hold up the top compartment lid....I gotta go take another look....struts are easy to do.
Did find another not so good problem....the right side exhaust piping between the cat and the joint to the over-axle section has two splits in it. One about 8", other 6". Not sure if I can weld the splits closed or may be time to drop alot of $$$$ on a cat back system.
And now for a somewhat dumb question....what octane does the LS1 require? I did not get an owner's manual or any type of manual. My '96 LT4 requires 92 min.
Brakes and clutch are bleed, rust removed from rotors...well not from the cooling vanes... brake pads look fine.
No luck on getting the power mirror pins yet...still working on that. About ready to remove the dash pad to get the HUD out and see if it can be fixed. Have read alot on the HUD repairs....hope I can fix mine.
Took battery and battery tray out....no acid damage...just leaves and sand...came from Ft. Myers, FL......ended-up removing the aft access panel from both front fenders so I can clean eveything out.
Appreciate all the comments and help....keep them coming for awhile.
Old Jan 26, 2016 | 08:46 PM
  #37
JR-01's Avatar
JR-01
Run top tier premium for best results and for cheap insurance put an acid absorbing mat under the battery for about 5 bucks.
http://www.batterymart.com/p-battery...FQ2HaQodI6UAKg
To New C5 Owner
Old Jan 26, 2016 | 10:01 PM
  #38
LannyL81's Avatar
LannyL81
Premium..got it.
Another question... the 'bag' for the lumbar air pump is missing on driver's side..... are there replacements??
Old Jan 27, 2016 | 07:21 AM
  #39
tmirisola's Avatar
tmirisola
Good luck with the new ride. Great color
Old Jan 27, 2016 | 08:48 AM
  #40
NMYDNA's Avatar
NMYDNA
Default Nice Color
Now the mod's and what to do next.
