Vacuum leak on map sensor
Old Jan 26, 2016 | 12:08 AM
Gangsta_Vette's Avatar
Gangsta_Vette
Default Vacuum leak on map sensor
Getting map sensor code p0106 car was tune wit this code come to find out I had 1 line not connected only the one running to booster. Map sensor is in the lil clip that holds it in position but I'm able to move up an down very bad so I removed intake an notice grommet was warn out bad an had a small tare . Before everything was removed I sprayed starting fluid an RPMs when up to 1k so that's telling me I have a leak can this mess everything up reason y my car goes into reduce engine power . I dnt think tuner is reading the extra vacuum is coming in ..can this leak throw off all the tune
Old Jan 26, 2016 | 07:06 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I would say yes !!!!!!
