Steering?
Old Jan 30, 2016 | 11:17 AM
Vanover's Avatar
Vanover
Default Steering?
When I'm making a turn my my steering wheel doesn't seem to return to straight very fast.almost like I have to help it get back straight.this is at slow speeds,like at intersections,when I'm making a turn.any thoughs?
Old Jan 30, 2016 | 01:28 PM
dadaroo's Avatar
dadaroo
Old Jan 30, 2016 | 02:05 PM
Rexde1's Avatar
Rexde1
Pull the codes you must.
Old Jan 30, 2016 | 02:48 PM
jpm995's Avatar
jpm995
Is power steering fluid level ok? Tire pressures?
Old Jan 30, 2016 | 03:28 PM
Those are two areas that I would check. Is there any noise coming from the power steering unit when you turn the wheels?
Old Jan 30, 2016 | 05:04 PM
LoneStarFRC's Avatar
LoneStarFRC
Aside from any fluid/pump issues, your caster adjustment on your alignment may be way off. If all else fails, get it to an alignment shop. Get it checked out.
HTH
Old Jan 31, 2016 | 07:43 PM
Vanover's Avatar
Vanover
I haven't had time to pull codes,I'll do that tomarow.there is no noise,the fluides are good,I had an alignment in OCT. I've had it almost a year,and it's always been like that.the tires have less than 5000 miles,I put them on in SEPT.
Old Jan 31, 2016 | 09:04 PM
LoneStarFRC
Originally Posted by Vanover
............,I had an alignment in OCT. I've had it almost a year,and it's always been like that.........
You say "it's always been like that" even after a visit to the alignment shop? It's entirely possible the alignment shop set your caster wrong! Correct caster setting is even more important on vehicles with wide(r) front tires. Wider tires accentuate the "tramlining" effect if the caster is not right. It should be in the 6.5º - 7.5º range, depending on year, which you don't state.
Old Jan 31, 2016 | 09:21 PM
Vanover's Avatar
Vanover
It's an 03. Ill take it back and see what it's set at.fire stone did it. I'll let them know what it sould be.
To Steering?
