MGW shifter issue
Old Feb 9, 2016 | 10:11 PM
Nyt_Muves's Avatar
Nyt_Muves
Default MGW shifter issue
Ever since we installed the MGW going from 4 to 5 is a little challenging. There is play in the stick while in 4th gear left to right. So if you don't move the stick right to take up the slack before leaving 4th you will often end up back in 3rd instead of 5th. I was at my transmission guy yesterday helping a friend drop off his BMW for a clutch and I asked the mechanic about it. He told me it sounds like I got a bad shifter because there is nothing else that could cause that. Is that a possibility? I put the stock shifter back in and tried it and the problem was solved. Put the MGW back in and the problem is still there.
Thoughts? Anyone else experienced this? I love the shifter but find this very annoying. And I did the lower box when I did the shifter.
Old Feb 9, 2016 | 10:14 PM
El original's Avatar
El original
Call George at MGW, he knows everything related to his shifter. He da Man!!
Old Feb 9, 2016 | 10:16 PM
StingrayRebel's Avatar
StingrayRebel
check the shifter box alignment and make sure all the bolts are tight... have a look at this thread it might be helpful, https://www.corvetteforum.com/forums...ervice-m6.html
Old Feb 9, 2016 | 10:24 PM
Nyt_Muves's Avatar
Nyt_Muves
Thanks.
According to the video instructions the alignment is perfect. I will check out that thread. Don't know if it's related but it pops out of reverse too.
Old Feb 9, 2016 | 10:36 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
mine does not have any slop,but I do have to push the shifter towards 5th ,never went into 3rd ?????
Old Feb 9, 2016 | 10:38 PM
10-94's Avatar
10-94
The only issue I had with mine was adjusting the shifter too low which made shifting it nearly impossible.
Old Feb 9, 2016 | 10:48 PM
Nyt_Muves's Avatar
Nyt_Muves
And the slop is only in 4th and its while 4th is engaged.
Old Feb 9, 2016 | 10:50 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I would agree ,to call George he is always willing to help !!!!!!
Old Feb 9, 2016 | 11:09 PM
Joepro95's Avatar
Joepro95
Make sure the shift rod pinch bolt is as tight as you can get it without stripping it, I had slop in my MGW, though it was tight enough, I was wrong...check that first, other than that time to call MGW.
Old Feb 9, 2016 | 11:18 PM
Nyt_Muves's Avatar
Nyt_Muves
Thank you! I'll check that.
Old Feb 9, 2016 | 11:21 PM
StingrayRebel
that's why I was suggesting he check the thread out that I linked, I didn't feel like typing it all out again
Old Feb 9, 2016 | 11:23 PM
Nyt_Muves's Avatar
Nyt_Muves
That link was a huge help. Thank you.
Old Feb 9, 2016 | 11:59 PM
StingrayRebel
hopefully it's something that simple... I have an older mgw shifter in my car and it has been great since I've owned it, I don't have any experience with his newer shifters with the lower box though
Old Feb 10, 2016 | 12:12 AM
Nyt_Muves's Avatar
Nyt_Muves
I love the shifter. Well made. Vastly superior to stock feel even with this little issue. I'm betting it's something stupid and that's why I figured posting this was worth the time. I was figuring that as with most things I'm not the first one to experience it and this crowd has been amazing at helping any time I've had any issue. Please don't misunderstand or think I regret this purchase. I just want to work the kinks out.
Old Feb 10, 2016 | 08:32 AM
TXGS507's Avatar
TXGS507
I am sure that it is something simple... Perhaps something that you overlooked. A buddy and I installed mine in about an hour... It's perfect in every way. No slop, no jumping out of reverse or the like. As others have said, check it and if it doesn't work out, call George.
Is your the flat stick?
Old Feb 16, 2016 | 11:27 PM
Nyt_Muves's Avatar
Nyt_Muves
Problem solved. It was 100% install error and no reflection on the product. It was the bolt in the little pinch clamp that secures to the shaft. I thought I had it tight enough. I was scared of stripping it. I followed advice posted above. Re aligned everything and tightened that torx about 3/4 turn further. Voila no more issue. Feels like it should. No more searching for or popping out of reverse. Throw between 2-3 and 4-5 are 1/3 of what they were. No more play or slop while in gear. The shifter is everything promised and more.
New problem. lol. I think I cracked the stock shift **** trying to get it tight so now I need to pick a new shift ****.
Old Feb 16, 2016 | 11:36 PM
StingrayRebel
To MGW shifter issue
Old Feb 16, 2016 | 11:47 PM
Nyt_Muves's Avatar
Nyt_Muves
Neutron82, it was that fastener listed and circled in red in that link you posted. I felt like an idiot. I really thought I had it tight enough and was seriously worried about stripping the bolt or the threads on the fitting. Thank you and thank everyone for the input and help. I feel like I got a new and better car today. The difference is that dramatic.
Old Feb 16, 2016 | 11:49 PM
Nyt_Muves's Avatar
Nyt_Muves
This was it. The whole issue. And just like you I thought I had it tight. Surprise. Thank you for the help.
Old Feb 17, 2016 | 12:07 AM
Joepro95's Avatar
Joepro95
