Noise at Startup
Old Feb 12, 2016 | 06:07 PM
Ronbo1786's Avatar
Ronbo1786
Default Noise at Startup
Over the last couple of days when I start my car there is a noise that I can't determine the cause of. I know the sticky says that these cars sound like a sewing machine at startup from the valve train but this is much louder than a sewing machine. I also noticed the volt meter reads around 11-12 while the noise is going on but as soon as it stops the volt meter jumps up above 13. Could it be the alternator?
Also, the noise only occurs if the car has been sitting for a while and it's cold.
Thanks in advance for the help!
Old Feb 12, 2016 | 06:21 PM
dadaroo's Avatar
dadaroo
Hard to say. Pull off the alternator belt and try it again. If it still makes noise try removing the A/C belt.
Mr. Sam
Old Feb 12, 2016 | 06:23 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
That doesn't sound like valve train to me. Hard to say what it is but if your volt meter continues to have that jump in voltage, that might be a good place to start. I'd use a stethoscope and see if the noise is much louder when you put the stethoscope on the alternator housing vs putting elsewhere on the engine.
Old Feb 12, 2016 | 11:29 PM
Sea Vette's Avatar
Sea Vette
Sounds like a really bad bearing in one of the pulleys. I'd take off the serp belts and check for noise/play/wobble in all the pulleys and idlers. I wouldn't expect a sound like that to magically disappear when the cars warms up though. Strange.
Old Feb 13, 2016 | 12:28 AM
Hope you can trace it down and it is a fairly easy fix.
Old Feb 13, 2016 | 10:11 AM
BSenzina's Avatar
BSenzina
I agree with the bad bearing in SOMETHING ! ! I had an A/C compressor go bad that made a terrible racket similar to this. I hope it doesnt leave you stranded on the side of the road.
Old Feb 13, 2016 | 11:49 AM
LoneStarFRC's Avatar
LoneStarFRC
Have you crawled underneath and looked/checked for anything obvious? Check for loose fasteners, panels, loose starter bolts, etc.........
Old Feb 13, 2016 | 03:25 PM
El original's Avatar
El original
Hopefully you are not low on oil, check, also look for debris around alternator housing eg. roller bearings as they are spit out when its failing.
Old Feb 13, 2016 | 04:30 PM
Sea Vette's Avatar
Sea Vette
I'd also suggest turning on your AC to see if that stops the noise. If the compressor clutch bearing is bad, I would think that engaging the compressor would stop the noise.
Old Feb 13, 2016 | 06:03 PM
LoneStarFRC
Something else came to mind and that is your A.I.R. pump. It mainly only operates on startup and the engine is in Open Loop mode, as the engine warms and the O² sensors heat up, it shuts off as the the engine goes to Closed Loop.
Left front, below the headlight area.
Old Feb 16, 2016 | 04:16 PM
LoneStarFRC
And the winner IS??
Old Feb 16, 2016 | 04:19 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by LoneStarFRC
And the winner IS??
the neighbors snow thrower
Old Feb 16, 2016 | 04:20 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Sorry OP
Old Feb 16, 2016 | 04:26 PM
LoneStarFRC
Old Feb 19, 2016 | 10:39 PM
Ronbo1786's Avatar
Ronbo1786
Sorry all, since I work all week I haven't been able to troubleshoot the issue. I did create a video hoping that might help everyone visualize the problem.
Tomorrow I'll be popping the hood and trying to determine the cause. The most difficult part is the noise only lasts 2-4 minutes at startup and then I have to wait 3-4 hours without driving it to make the sound come back.
Thanks again for taking the time to help.
Old Feb 20, 2016 | 05:21 PM
Ronbo1786's Avatar
Ronbo1786
Thought today was going to be an easy relaxing day.
Plan was to remove the belts to eliminate cause of engine noise. While I was at it I replaced the plugs too. After removing the two belts and starting the car the noise was gone. So that narrowed it down. Put the belt to the air pump back on and started the car. There was that damn noise again. At least now I've narrowed it down. BUT, when I went to shut off the car the engine wouldn't shut down. No matter what I did it kept trying to run almost like dieseling but not quite. When I put the key back to start it would run normal again. So I turned the key to off, put it in 5th and shut it down that way BUT, the battery was boiling and I quickly grabbed the wrench to disconnect the negative and it was smoking finally got it disconnected from positive and negative terminals but the negative end was melted.
What the Hell???
Old Feb 21, 2016 | 03:25 PM
Ronbo1786's Avatar
Ronbo1786
What the Hell???
Where do you folks think I should start?
1. Replace the melted negative cable
2. Have the battery tested
3. Reattach the alternator belt
My biggest concerns are why wouldn't the car shut off and when I got it to shut off why did the battery boil?
Thanks for your ideas!
To Noise at Startup
Old Feb 21, 2016 | 04:15 PM
Sea Vette's Avatar
Sea Vette
When you say air pump, do you mean AC compressor?
I would get that battery tested first and fix the cable. If I understand correctly, you were running the car without the alternator belt, which would have put a heavier than normal load on your battery. I wouldn't think that this would make the battery boil, but if the battery was already weak or had some kind of internal issue, this may have tipped it over the breaking point. How old is the battery?
As far as the car continuing to run even with the key off, that one is beyond my understanding. If nothing else I'll bump this back to the top and hopefully someone with more knowledge than I can help.
Old Feb 21, 2016 | 04:32 PM
Ronbo1786's Avatar
Ronbo1786
Thanks Sea Vette!
Your right it is the one that drives the AC. I'm wondering if only running one belt would have caused the engine not to shut off.
Old Feb 21, 2016 | 04:53 PM
Sea Vette's Avatar
Sea Vette
How long did it continue running after you shut the key off?
