[Z06] My "fix the small things" winter build
Old Mar 11, 2016 | 09:09 PM
nullpointer's Avatar
nullpointer
Few updates worth mentioning.
If you get the vettenuts insulation kit, they do not cut holes wide enough around the seat mounting bolts. The plastic covers will not fit due to increased thickness.
I had to remove the driver side carpet to cut them larger, still need to do the passenger side. The driver side seat is rebuilt, and installed.
Radioflyer headlights installed, and look awesome. Still need to aim them. Also I bolted the ballasts to the wheel wells.
While changing the blower oil, the female end separated from the braided line. I can't run the car until I get a new drain line, I called Chris@ECS and a new one will be here Tuesday.
I cheaped out on oil and got Pennzoil Ultra, going to add some moly due to lifters/cam.
Still need to:
  1. Change blower oil
  2. Install new drain line
  3. Add motor oil
  4. Fix passenger insulation/install seat
  5. Install shroud
  6. Drain wiper fluid and fill with 100% meth
Nothing major, I should be out driving wednesday night
Old Mar 11, 2016 | 09:10 PM
nullpointer
Originally Posted by Tj Pal
TR04Z Live nearby. I'll be looking forward to seeing your car when the cruises start.
Sounds good
Old Mar 11, 2016 | 09:42 PM
fisher auto's Avatar
fisher auto
Originally Posted by Atrain59
I really like that rad shroud. I just bought my ECS 2200 kit last summer and did not get this. I'll have to get one for sure. How much was it?
Dam me too! Guess I'll be ordering mine, thanks for posting!
Old Mar 17, 2016 | 08:53 AM
nullpointer
So I had a moment of ignorance, and thought my drain line from the blower was broken. It was not, when you loosen the nut, the female end spins on the line due to how the fitting works. Oh well, now I have an extra line.
Blower oil changed, motor oil added. This weekend I will finish the interior. Weather is not as nice as I hoped, calling for some snow this weekend, hope they are wrong like normal.
Old Mar 17, 2016 | 09:47 AM
nsogiba's Avatar
nsogiba
come on, last couple days have been purdy.
Old Mar 17, 2016 | 10:01 AM
C5Dobie's Avatar
C5Dobie
Damn I was supposed to go out to Saratoga this weekend!
Old Mar 17, 2016 | 10:12 AM
nullpointer
Rained and hailed in buffalo yesterday, was nicer near my house in the hills though.
Between last night and when I just checked it, weather changed from snow to rain
nsogiba's Avatar
nsogiba
ehhhh, i took mine to work, hailed on it, fiberglass doesn't dent, she'll be fine!
Old Mar 17, 2016 | 10:17 AM
nullpointer
It's awesome out here today (working from home). I may drain the wiper fluid, fill with meth, and take her out.
Edit: What area downtown do you work?
Old Apr 9, 2016 | 09:41 PM
Jason Zajac's Avatar
Jason Zajac
Walter White approves of the Meth fill up. Speed Shop will be stocking the "blue" stuff
Old Apr 13, 2016 | 08:09 AM
nullpointer
I still have a lot to burn through, I'll sure as **** try though lol
Old Apr 15, 2016 | 01:20 PM
nullpointer
I think I found the suspension settings that I like best for the street.
Front
Compression: 4
Rebound: 8
Rear
Compression: 3
Rebound: 5
Party time
R888s still can't hold 1/2/3 gear, but the roads are still a bit chilly. Once they warm up I will dial in the suspension for drag racing and see if it helps.
Only things left on the list are aiming the headlights and installing the shroud. ECS idler might need new bearings, they are a bit loud and this seems common.
It was nice to cruise and not break my back on every bump, and hear music. It's going to be a great summer with the car
Old Apr 15, 2016 | 01:22 PM
  #33
nsogiba's Avatar
nsogiba
headed to C&C sunday?
Old Apr 15, 2016 | 01:23 PM
  #34
nullpointer
of course, you?
Old Apr 15, 2016 | 01:24 PM
  #35
nsogiba's Avatar
nsogiba
Yes, I am meeting a couple buddies and should be there around 9. I'll be lookin' for ya. Maybe some other board members on here will attend as well. Weather is looking perfect, should be a big turnout
Old Apr 15, 2016 | 01:25 PM
  #36
nullpointer
Sounds like a plan I know of 1 other member that will be there. Weather will be awsome
Old Apr 15, 2016 | 11:34 PM
  #37
Tj Pal's Avatar
Tj Pal
Is this cruise located in the Orchard Fresh parking lot? I'd like to check it out.
To My "fix the small things" winter build
Old Apr 16, 2016 | 06:12 AM
  #38
nsogiba's Avatar
nsogiba
Yes it is, 9am Sunday
Old Apr 16, 2016 | 04:52 PM
  #39
JETninja's Avatar
JETninja
WA Events Coordinator
Like to see a review of the Viking shocks, did some research on them but have not found any real reviews as of yet..
Old Apr 18, 2016 | 11:03 AM
  #40
Jason Zajac
I thi
.....ECS idler might need new bearings, they are a bit loud and this seems common.
Get the bearings and bring the Jack Honey. I have the iced tea
