why do i need a catch can?
Old Feb 23, 2016 | 11:38 AM
  #41
CriticalmassGT's Avatar
CriticalmassGT
Originally Posted by firstvette99
the ls1 engine was developed through thousands of hours of testing.gm did not put a catch can on the final design. why do I need a aftermarket one on my ls1 engine.03 mn6
any input will be greatly appreciated,especially any automotive engineers out there.
You don't. Your engine is not Direct Injected, so there's no worry of coking on the valves.
As long as you are using a top tier fuel, it's not something you need to worry about, the fuel washes everything down and gets rid of the deposits that form on the valves of direct injected engines.
Also, Catch Cans do NOT STOP oil from getting into the manifold, it only reduces it. So what your doing is simply delaying the inevitable with a DI engine, and that is a tear down and cleaning.
And if a Catch Can is not installed and maintained properly you can end up running lean due to air leaks. They are a waste of money for a non-DI engine.
Old Feb 23, 2016 | 11:56 AM
  #42
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
What did you do for GM Evil Twin?
Old Feb 23, 2016 | 02:43 PM
  #43
ZZ06's Avatar
ZZ06
What in the world......
Old Feb 23, 2016 | 03:37 PM
  #44
mrr23's Avatar
mrr23
St. Jude Donor '15
We've been waiting on that answer
Old Feb 23, 2016 | 04:35 PM
  #45
chasboy's Avatar
chasboy
Oldtimer
Bill, thanks for your insight and knowledge. Reading "All Corvettes are Red" really helped me appreciate how much went into the C5. I didn't appreciate the difference until I drove 2 C4's in my quest to return to Corvette ownership.
Old Feb 23, 2016 | 04:55 PM
  #46
johnodrake's Avatar
johnodrake
Moderator
Closed before the pissin match gets to full force.
