Finally got my Bi-xenon projectors from radioflyer and I have to say, they were worth every penny! Install took a few hours but anyone can do it very easily. I had the same type of projectors when I did yhe retrofit on my Camaro and they're super bright and have a great cutoff. If anyone is on the fence about these...DO IT! Pics are before, after, and then with the highbeams on up against a conrete wall from 30 or 40 feet away
I put mine in late fall and only got to use them a couple of times before winter. They are a huge improvement over stock. Very happy with the product and George's service.
True! My only complaint is that the cutoff is so good that I can now see the headlights shake a little when going over bumps. Nothing bad about your kit, just a part of having 12 yr old pop up headlights i guess
It takes some getting used to. Modern luxury cars use an auto-leveling system which while possible is not cheap and would be prohibitively expensive to engineer on pop up headlights
