How do you replace shifter cable 04 C5 automatic
Old Mar 18, 2016 | 08:12 AM
delect46's Avatar
delect46
Cruising
Default How do you replace shifter cable 04 C5 automatic
Any idea how to replace shifter cable on my 2004 C5 automatic
Old Mar 18, 2016 | 08:32 AM
feeder82's Avatar
feeder82
https://www.corvetteforum.com/forums/c5-tech/2343391-a4-shifter-cable-how-to-replace.html
Old Mar 18, 2016 | 08:34 AM
delect46's Avatar
delect46
Cruising
Thank you !
Have a great day
Old Mar 18, 2016 | 06:56 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Have transported to dealer, pick up when done.
Old Mar 18, 2016 | 07:32 PM
delect46's Avatar
delect46
Cruising
I don't trust dealers , how much do you think it will cost
Old Mar 18, 2016 | 07:36 PM
mikeg22485's Avatar
mikeg22485
tow bill $75 parts and labor $425.00
Old Mar 18, 2016 | 07:40 PM
Mastertvtech's Avatar
Mastertvtech
Had it done yesterday as a preventative measure at a local Corvette shop. $299 parts and labor.
Old Mar 18, 2016 | 09:37 PM
Thanks for all the info. Saved this for future use.
Old Mar 18, 2016 | 09:55 PM
delect46's Avatar
delect46
Cruising
Thank you now I just need to find reputable mechanic shop here in northern Colorado
Old Mar 18, 2016 | 10:47 PM
raff's Avatar
raff
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22
Naturally, location influences pricing --
south Georgia
Replaced 2 years ago at Chevy dealer --
Total = $269 ($170 labor and $99 parts)
Old Mar 19, 2016 | 06:37 AM
SG Lou's Avatar
SG Lou
Chances are this is all you will need to repair your cable...
http://www.ecklerscorvette.com/corve...1997-2004.html
And here's a cheaper alternative :
http://www.dormanproducts.com/itemde...1&SEName=14041
Old Mar 19, 2016 | 02:12 PM
delect46's Avatar
delect46
Cruising
Cable looks good on transmission end , and shifter end, cable moves back and forth when I shift .could it be possible sheath that covers cable slipped ?
Old Mar 19, 2016 | 04:25 PM
BADBIRDCAGE
Mine was just under $500.00. If I have a cable problem within the next year (not very likely as the original lasted 15 years) I can get it fixed at no charge at any Chevrolet dealership.
If you are five states away and you have a problem your specialty shop will also fix it at no charge. All you have to do is get the car to them.
Old Mar 19, 2016 | 08:40 PM
SilverC54me's Avatar
SilverC54me
Just dealt with this. the cable sheath came out of its mount on one end preventing the shifter from working properly.
Had to drop the exhaust and tunnel plate to change it.
Gary
Old Mar 20, 2016 | 09:22 AM
BADBIRDCAGE
Originally Posted by thisMSGgood4me
That's true, but like you said, "not very likely as the original lasted 15 years."
Absolutely correct, however, there CAN be a defective part manufactured and my experience is that if there is one it ends up installed on my vehicle.
Old Oct 12, 2016 | 09:12 PM
davidj1961's Avatar
davidj1961
7th Gear
I had to replace the shift cable on my 2000 C-5. If you cant get it on a lift to remove the exhaust and tunnel plate find a local tranny shop with some Vette experience. I bought the cable from Rock Auto and had a local shop do the labor. $59 for the part and $190 for the labor. I removed the shift console and hand shifted the tranny with cable from park into drive. The shop was ready so I could drive it directly onto the lift since shifting it with the cable again would be a problem. The old cable had a bend in it, replacement was only option, back on the road.
Old Oct 12, 2016 | 10:16 PM
sirdano's Avatar
sirdano
Mine total cost was $600 but I had them flush/drain and fill the transmission since it was there.
And mine broke at that plastic piece but knowing my luck i change that a week late the cable goes out so I had them change the whole cable.
Old Oct 12, 2016 | 10:30 PM
davidj1961's Avatar
davidj1961
7th Gear
Good move replacing the cable. I replaced the plastic bushing on the shift lever earlier this year. Thought I was all set for 6 bucks, but then it failed again 2 months later, luckily it came off in my driveway. Looking back I'm sure the cable problem was the culprit and was putting pressure on that bushing causing it to fail again.
To How do you replace shifter cable 04 C5 automatic
