I changed it back in October when purchased, driven 5000 miles, pretty certain full 6.5 qts after change.
I was between the 2 dots on the dipstick after a couple thousand, and now after 5000 was between the 2 dots again, added almost half a quart each time.
If you are on the lower dot does that equal 1 quart low?
Would you guys expect to go through a quart every 5000 or 10,000 miles?
I wouldn't say that is normal, maybe a higher mileage car. I do 3K oil change intervals on my 98 with 106K and my oil level is still right on the mark at every oil change. As someone else mentioned maybe you didnt completely fill her up when you did an oil change?
You're going to hear and read varying opinions on oil consumption. Some C5s will consume no oil, some may see minor consumption. The thing is a little oil consumption between changes is not uncommon and should not point towards any issues. Major oil consumption will obviously point to a problem.
You will lose some oil through operation of the PCV system. Oil is pushed through the intake and burned off as part of the combustion process; this is normal operation. The year C5 you have will also be key. Earlier C5s tend to burn off a bit more oil due to their PCV setup. For 2001/2002 cycle the PCV setup for the LS1 was redesigned. Specifically 2001 cars received a service bulletin - if my memory is correct - to install the later 2002-2004 style.
As owner of a '99 model, I have observed approximately half a quart of oil burn off between 5,000 mile oil changes.
Sorry I just re read your post.... You're experiencing blow by. Look into installing a catch can. Such a common add on with these cars because of the same thing you're experiencing I'll put one on when I go F/I...
If you don't consume any oil at all in 5000 miles, you must putt around at 1300rpms all day.
Let me borrow one of these "not a drop" cars and I'll bet the farm it needs at least one quart by 5000 miles.
OP, that sounds like standard oil consumption. Even GM stated that less than a quart within 1000 miles is normal for these cars. (I believe that's the mileage they claimed)
Personally I wouldn't even sweat adding 2 quarts within 5000 miles, but then again I drive my car hard
You're going to hear and read varying opinions on oil consumption. Some C5s will consume no oil, some may see minor consumption...
The year C5 you have will also be key. Earlier C5s tend to burn off a bit more oil due to their PCV setup. For 2001/2002 cycle the PCV setup for the LS1 was redesigned. Specifically 2001 cars received a service bulletin - if my memory is correct - to install the later 2002-2004 style....
Certain 2001s were affected by a piston ring issue. GMs fix was to tear down the engine and replace a single piston ring on cylinder number .... 2 ... IIRC.
Again IIRC, the indicator was using 1/2 quart or more between oil changes.
My car was in the sn range, but I elected to not tear down the engine, just monitored usage. Never had an issue, and consumption never increased.
I've never owned a v8 that did not use some oil between changes, this consumption sounds "normal enough" to me. and it is directly proportional with how hard car is driven. Also my mechanic always says you should check your oil in the morning before you start the car and should be in the middle of range not the top.
