I have a torch red C5Z, and it has the side moldings installed on the fender/door...
I'm not a huge fan of this look, and was wondering if anyone has removed theirs? I'm scared to attempt it without advice first, I have no idea how long they've been on there.
Can someone explain the proper process to avoid any paint damage?
do a search , someone posted about that a couple weeks ago . think he used a credit card and also some fluid which i don't remember . came out really well .
Fishing line and good gloves!!! And IIRC 3M has a buffing wheel that will help with the glue removal.
A piece of welding wire from a collision center will work, just keep it tight to the molding and wear gloves as mentioned above. Also, as mentioned above, using a 3M rubber or foam disc on the end of a drill at slower RPM will remove the glue left behind. I spent a few decades as a production painter and the heat will bubble the paint if you're not careful....be cautious or have a collision center pull them of as it wouldn't be that expensive (<100 bucks).
A hair dryer, fishing line and a helper is really all that is needed to get the moldings off. For any residue left behind, use something like WD40 or an adhesive remover. The helper is used to help pull on the molding while you saw through the double sided tape holding the molding on.
Just be aware that there could be some fading of the paint compared to what is under the molding and there have been instances where some paint came up with the molding, but the paint lifting is pretty rare.
i have always used 3m adhesive remover and hair dryer. let it soak a few minutes and peel back slowly. afterwards you can remove the exiting glue with the 3m and it will not harm the paint. this is the quickest/easiest method in my opinion.
Thanks!
Start by removing just one of the small sections. If you don't like the result it's not much hassel to put it back on.
Thanks, was just concerned about the fiberglass and paint
Process seems to be fairly universal, little heat and some patience!
If you can heat it up a bit and use 30lbs. fishing line to 'saw' the trim off. Any remaining stickum from the two sided tape can be removed with any number of solvents such as 'GooBgone',
The only problem with the paint would be if the door has been repainted without the body side moldings (the correct term for this spears) removed first.
Happened to me...It sucked.....had to go out and buy more tape and stick the damn things back on...
I removed mine on my navy blue metallic '01 vert. Easy job, time-consuming... Little to no fading. A good paint correction afterwards (thanks Ted Y!) and it looked like they were never there.
