[Z06] Replacing Harmonic Balancer
Old Mar 29, 2016 | 11:15 PM
trav731's Avatar
trav731
Default Replacing Harmonic Balancer
Hey guys, I am replacing the Harmonic Balancer on my car and was wondering if their is anything else that you would recommend be replaced while the work is being done. Thank you guys!
Old Mar 30, 2016 | 09:19 AM
gunluvS14's Avatar
gunluvS14
steering rack bushing, since very likely you will have to loosen the rack the clear your harmonic balancer
Old Mar 30, 2016 | 10:27 AM
StingrayRebel's Avatar
StingrayRebel
cam swap
Old Apr 1, 2016 | 01:03 AM
trav731's Avatar
trav731
Sweet, thank you! I think I will have to do that, I love the way the steering in the Corvette feels and anything that makes it feel better is all good in my mind.
Old Apr 1, 2016 | 01:05 AM
trav731's Avatar
trav731
cam swap
I would love to, eventually looking to do an aggressive cam and some head work but think I need to start with something simpler for my stock Z06 right now lol. Thinking maybe getting headers as the next big project for the car.
Old Apr 1, 2016 | 02:47 AM
Cheesecake 07's Avatar
Cheesecake 07
Theres not really much preventative you can do with the rack removal. New bushings can't hurt.
Take your time with it, its a pain in the *** your first go around. Be careful with the aluminum ears on the subframe as your sliding the rack to the passenger side.
I take the fans out...helps with room. Maybe not necessary but takes 5 min to save you 30 fighting it later
I picked up 30rwhp with headers, X, intake and tune...car felt totally different in a good way
Old Apr 3, 2016 | 01:58 PM
Pumba's Avatar
Pumba
Definitely - Your oil pump!
Either one of the two Melling oil pumps listed are a vast improvement over the GM pump.
Old Apr 4, 2016 | 07:07 AM
555ss's Avatar
555ss
pin the balancer to the crank and use and ARP bolt with red loctite.
Old Apr 4, 2016 | 07:36 PM
aquachuck1's Avatar
aquachuck1
Default hb
Timing chain cover crank oil seal.
Old Apr 4, 2016 | 08:11 PM
Paul 75 L82's Avatar
Paul 75 L82
A 228 cam at 112 really wakes up the Z06.
Old Apr 4, 2016 | 10:57 PM
RC000E's Avatar
RC000E
A guy reads this thread and makes him feel like once your eyeballs are looking directly at the harmonic balancer it's time to rebuild the whole motor...lol.
Old Apr 13, 2016 | 07:48 PM
trav731's Avatar
trav731
Thinking about getting to that eventually just got the harmonic balancer put on and the car running. Can't decide yet whether to keep it N/A or go with a pair of turbos.
Old Apr 13, 2016 | 07:50 PM
trav731's Avatar
trav731
Will probably get to the oil pump when it gets more power to it, right now it's stock . But thank you for the advice.
Old Apr 13, 2016 | 07:51 PM
trav731's Avatar
trav731
I should have done that, completely forgot. I will eventually come back to it when it starts to make more horsepower. Thanks for the advice
To Replacing Harmonic Balancer
