Battery question
Thanks,
Mark
Your battery should be able to let your car sit idle for a GOOD MONTH!
What battery do you have? Batteries have a CCA rating and a RESERVE CAPACITY Rating
The Reserve Capacity should be 120. What is your reserve capacity rating??
What is reserve capacity of a battery?
Reserve Capacity (RC) is a very important rating. This is the number of minutes a fully charged battery at 80 ° F will discharge 25 amps until the battery drops below 10.5 volts. An amp hour (AH) is a rating usually found on deep cycle batteries.
When you shut your C5 down and walk away, after a few minutes it goes into SLEEP /SECURITY Mode.
In that mode, it sheds all non necessary electrical loads (that the BCM has control over) and the maximum battery CURRENT draw in milliamps should be 25-30 milliamps.
To measure this value, you have to disconnect the battery NEGATIVE TERMINAL and set up a Multimeter to read 10 DC AMPS. Insert the ammeter in SERIES with the NEG battery terminal and NEG battery cable.
After approx 12 Min, you should be at the lowest SLEEP current reading. If it is HIGH, you need to look for what ever is drawing excessive current or not turning off.
EXAMPLE, Interior lights set to remain on all the time by accident.
BC
If I am not going to drive mine for a week or so I put it on the tender. I have found my car is happier with a fully charged battery.
BC
When I have a good proper battery in my 02 ZO6 and or my 11 Grand Sport, its sits idle for an easy 20-30 days and it will STILL CRANK.
Granted itS NOT a properly charged battery at that point in time. My point is, it can and should start AFTER SITTING for a period of time.
Do you think people would be happy if they could not leave their C5/C6 in an air port long term parking lot for a 4-5 day business trip. CAR manufactures SPECIFY what reserve capacity is necessary for the car to be a NORMAL use car and be able to have your GRAND MOTHER OWN IT AND BE HAPPY..
So,,, what reserve capacity is the battery rated at and WAHT is your sleep current draw??
And, FYI, if you get an AGM battery, it MUST BE FULLY CHARGED PRIOR TO FIRST USE or it will prematurely fail. Do not rely on the guy in the battery store telling you it's good to go when you get it, you must charge it up first so be forewarned.
Interstate
MPT-78
CCA 800
CA 1000
RC 110
And in the 2 hours on the tender, it went from charging to charged.
Then I opened the hood and the light went on and it went back to charging, which I'm sure is normal...
By the way, thanks so much for all the help...
Mark
However I was waxing the car last week had the radio on for about 2 hours, tried starting, won't turn over , had to jump start.
