[Z06] Fuel setup questions???
Old Apr 6, 2016 | 11:59 PM
Albertpeterson's Avatar
Albertpeterson
Default Fuel setup questions???
01z06... A&a v3 t trim set up, long tubes, x pipe, mild cam...
I'm looking to upgrade my fuel system but really don't know what to get. Looking for recommendations for rails, pump, injectors and throttle body... Any input would be great
Old Apr 7, 2016 | 01:51 AM
StingrayRebel's Avatar
StingrayRebel
with those mods you're looking at an easy 650+... I was supporting a little over 700 with a racetronix harness, walbro 255 in tank pump, kenne bell 40a bap, meth, and 60lb injectors... ran that setup for a year or so and then ditched the bap, got some bigger injectors, and added a big secondary pump... it's better to have more fuel and not need it than need it and not have it... it really just depends how much you have to spend and how far you think you want to go... regardless of what pump setup you decide to run I would definitely recommend a racetronix harness and a dual nozzle alky control meth kit... don't waste your money on the throttle body the stock one will do just fine, same goes for the intake manifold... you can make plenty of power without touching those
