[Z06] Header Install - What Else?
Old Apr 8, 2016 | 08:32 AM
Sparty737's Avatar
Sparty737
Default Header Install - What Else?
I am having a local shop replace the stock headers with a set of XSpowers and air intake with a halltech venom next week and then tune everything. Was wondering what else I should have them do while they are in there?
2003Z - 33k miles, stock except for MGW shifter and B&B bullets (being replaced with stock TIs with new headers). I have owned for 2 years so unsure on last plug change (if any). I did all the fluids when I bought it.
Was thinking plugs and wires would make sense but is there anything else that people would recommend that would be easier to do with the header install now rather than later?
Also - any recommendations on plugs and wires?
Thanks all
Old Apr 8, 2016 | 11:10 AM
grantv's Avatar
grantv
Plugs as you might break one and they're cheap. Wires as they'll not come out alive. Iridium plugs and GMPP wires from Cultrag.
Otherwise sounds like you are good to go.
Old Apr 8, 2016 | 12:18 PM
Verrückt ZR1's Avatar
Verrückt ZR1
Did you have the headers ceramic coated? If not, it might be time for a tunnel plate.
Old Apr 8, 2016 | 12:51 PM
Sparty737's Avatar
Sparty737
I ceramic coated the headers - do you think that the tunnel plate would still be necessary? Not sure it would have that much impact on heat in the cabin given the ceramic coating, but I am trying to keep heat in the cabin to a minimum.
Old Apr 8, 2016 | 12:56 PM
Verrückt ZR1
I had my Super Pros coated front to back and zero issues with heat in the cabin. Unless your looking for a stiffer frame, your good to go.
Old Apr 8, 2016 | 02:37 PM
satxredvette's Avatar
satxredvette
160 degree thermostat, and maybe an oil catch can
Old Apr 8, 2016 | 02:38 PM
satxredvette
msd 8.5 superconductor wires and ngk v-power plugs
Old Apr 9, 2016 | 11:39 AM
spdislife's Avatar
spdislife
Plugs and wires. I would not tamper with the thermostat.
To Header Install - What Else?
