One solid engine mount survey
Old Apr 8, 2016 | 09:26 AM
nitrouspaul's Avatar
nitrouspaul
Default One solid engine mount survey
I am fabricating a semi solid mount here on the lathe it is basically a alum round with a capture groove top and bottom for 2 poly donuts with studs sticking out of both ends. the poly will sit on the cradle and block bracket with alum in the middle in an attempt to soften vnh.
I am unsure of the best side to install it on, garnering opinions here.
Old Apr 9, 2016 | 09:29 PM
nitrouspaul
ttt
