[Z06] head recommendation
Old Apr 10, 2016 | 10:26 PM
appliance guy's Avatar
appliance guy
Default head recommendation
Will be having a BTR stage 3 cam / springs/ push rods installed soon in my 02 Z. I don't have time to have my heads ported so I need to buy a set. Does anyone know of a particular head that works well with that cam ?
Old Apr 11, 2016 | 10:13 AM
appliance guy
AFR is recommending I go with their part # 1610 which is 230cc. Any thoughts ?
Old Apr 11, 2016 | 12:17 PM
Cheesecake 07's Avatar
Cheesecake 07
Id holler at Brian Tooley....he'll clean up a set of Trickflow 220's that will make just as much power w/o the inflated price
Old Apr 11, 2016 | 02:13 PM
zeevette's Avatar
zeevette
If you're in so much hurry that you need finished heads, I recommend Trickflow 215s. They're already to go, but you might need roller rockers. This was required years ago, and I'm not sure if that's still the case. The 220s mentioned above are not CNC'd, but perform nearly as well out of the box, and are cheaper.
Old Apr 11, 2016 | 02:43 PM
appliance guy
I found a set of 799's that have been port and polished. Milled to .030, manley valves, PAC 675 springs, ti retainers, compression 11:2:1....3,000 miles on them for $1,000.
799/ 243 are the same right ? Different mfg. Locations ?
Old Apr 11, 2016 | 03:05 PM
Cheesecake 07
Essentially same thing. Know who did the heads? Lot of sorry work out there
Old Apr 11, 2016 | 03:44 PM
appliance guy
Wegner Motorsports
Old Apr 12, 2016 | 03:45 PM
appliance guy
Ok, just pulled the trigger on the 799's
Old Apr 12, 2016 | 06:37 PM
TXGS507's Avatar
TXGS507
I am running TEA ported 799's... They flow amazing with my 414 stroker, ported FAST 102... Just my experience.
Old Apr 24, 2016 | 11:28 AM
kalayaan12's Avatar
kalayaan12
The 799's are made using a sand-casting process and have a much rougher appearance than the 243's which are much smoother looking by comparison.
Some have indicated that the 243's are worth an extra 5 hp over the 799's due to the more precise method they're manufactured by - however after porting and polishing there would be no difference in performance at all.
Old Apr 24, 2016 | 09:13 PM
NytmereZ's Avatar
NytmereZ
Although I never used AFR heads on any of my Chevys , they have matched head/cam/intake combos for a couple of my Mustangs with great results.
To head recommendation
