Tick master worth it?
For track applications, this is probably a great clutch and I admit it appears to be made very well. For street driving, this not the clutch master cylinder you want.
i daily drive my car got use to it only time it ever really bothers me is after 45 to 60 minutes in gridlock traffic other wise i don't notice it, kinda feels like cable clutch from a 90's mustang for comparison
The LS7 is a great clutch for spirited driving, some rolling pulls and maybe 1 or 2 passes at the drag strip but it won't last, I know clutchs are mainly driver dependent on how their abused and driven, but if I plan on abusing my car on a Daily basis its better to find something that can take the abuse. There are many different clutch choices for our cars from Mantic,Monster,Mcleod,SPEC,ACT,Exedy,Cen terforce,etc if you're trying to be cost effective see what different brands have to offer at the price points you're looking for and find info on drivers who've installed them on this forum. Every clutch is different not a singe perfect one out there for all purposes, especially considering all of us drive differently.
A slight increase in pedal pressure but it is a true race master cylinder that you can adjust the engagement point to your liking.
We put a few in a month.
http://www.americanheritageperformance.com/
Zeevette: Depending on clutch you have, the Tick MC is a HD part that flows more than a factory MC. However, there are instances that it's too much of a good thing. I replaced my clutch, FW, and all the hydraulics, using a Tick MC, and no more soft clutch after a high RPM run. Great, right? With my RPS twin, the Tick makes the pedal VERY stiff, and the engagement is about a 1/16", so driving it takes a very fine touch to drive smoothly. Your results may vary. …
I'd estimate the force required as about 2-3x "more PSI"; it's definitely a hard pedal, but one shouldn't have any troubles with it unless the left leg has a medical problem (bad knee, etc.). There's no doubt the pedal resistance would be no fun in a long cross-town stoplight-to-stoplight commute.
Ya'll oughta try the combination with a lightweight flywheel.
(Add a newly-acquired sensation of a touchy gas pedal to the mix and then go enjoy some commute traffic til you get used to it.) I drive the c5 only once or twice a week and after a month or just a little more, it's not so bad--but I don't have a leg problem--and I'm 64yr old; haven't pressed a weight in 35 years.
i didnt care for the ls7 myself felt weak and mushy when shifting aggressive the monster 2 has been a reliable clutch for me between both cars i have maybe 20k on it 440ish wheel with some drag strip use and aggressive driving hold really well
monster stage 2/tickmaster combo ZERO loss of clutch peddle even after back to back passes
i'm sure other will chime in about clutches they used
Centerforce recommended only using the stock master and slave in their documentation.
From what I've read over the years most of the issues are related to the clutch and not the hydraulics.
Btw the tickmaster gets connected to the clutch peddle and the bleeder to the slave cylinder witch if your doing a clutch the slave should be replaced too..
Yes, pedal pressure is harder but not horrible and engagement is quicker.
My hydraulic system is overbuilt now with Tick MC, Mcloed RST, Castrol SRF, and a Remote bleeder.
I had installed mine when at 385rwhp I was having issues with a hard pedal at WOT Shifting. NOTE: the Tick MC alone did not resolve the issue, what did was the new clutch (Mcloed RST).
So If you ask me now though if I was to do it all again I'd probably replace the clutch 1st, put Castrol SRF in, and use a new stock MC. If that didn't work, then a 3/4 Tick Master (stock size). Again the Tick MC is not horrible, but it's one of the mods that takes away some of the stock-level drivability. I also think that because the engagement is so quick the likelihood of breaking something is higher.
