Turn signal problems
Old Apr 14, 2016 | 10:12 PM
edbutler66's Avatar
edbutler66
Default Turn signal problems
My right front turn signal is acting like they do when the bulb is burned out but the DRLs light up. Any idea what's going on?
Old Apr 15, 2016 | 06:17 AM
dadaroo's Avatar
dadaroo
Could be the Multifunction Switch. What happens when you use the Hazards?
Mr. Sam
Old Apr 15, 2016 | 11:54 AM
Vanover's Avatar
Vanover
Old Apr 16, 2016 | 05:37 AM
Sids04's Avatar
Sids04
You have a bad bulb. I had the same issue..
Old Apr 16, 2016 | 07:23 AM
dadaroo's Avatar
dadaroo
He said the bulb worked fine. His DRL works so it is not the bulb.
Mr. Sam
Old Apr 16, 2016 | 09:18 AM
jd911's Avatar
jd911
I'm just asking, but aren't the turn signal/drl dual element bulbs?
Anyway, when my drl still worked and the turn signal would not (fast flashing of the dash turn indicator), it ended up being corrosion at the bulb socket. It seems the drl melts a hole in the lamp housing allowing water to enter, which results in corrosion of the electrical contacts of the socket.
Jim
Old Apr 16, 2016 | 11:48 AM
GCG's Avatar
GCG
Originally Posted by jd911
I'm just asking, but aren't the turn signal/drl dual element bulbs?...
The OEM bulbs have two filaments:
  • One for the DRL/Turn Signal
  • One for the Parking Light
Old Apr 16, 2016 | 12:39 PM
jd911's Avatar
jd911
Thanks. Maybe I was looking at the parking light, instead of the drl.
Jim
Old Apr 16, 2016 | 06:24 PM
Sids04's Avatar
Sids04
Like I said check the bulbs first. I made the same assumption about the DRL working as well.
Old Apr 17, 2016 | 10:12 PM
edbutler66's Avatar
edbutler66
Mr. Sam
I turned on the emergency flashers and they flashed at the proper speed except for the one on the front right side which didn't come on at all.
Old Apr 17, 2016 | 10:16 PM
Vanover's Avatar
Vanover
Bulb
Old Apr 18, 2016 | 07:07 AM
dadaroo's Avatar
dadaroo
OK, that tells me it is either the Right DRL relay or in the wiring. That just ruled out the MF and Hazard switch as an issue. Might want to swap the relays and see if the problem swaps sides. They are in the I/P fuse box.
Mr. Sam
Old Apr 20, 2016 | 01:31 PM
edbutler66's Avatar
edbutler66
so this is where I am. I swapped the micro relay for the drl left and right. That didn't change anything. I removed the relay for the drls and turned on the turn signal and the left side still worked. I went in under the car and removed both bulbs from the housing and they both work but not when the turn signnal is on for the right side. Any thought?
Old Apr 20, 2016 | 02:32 PM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
Hazard switch is going bad. Try just slightly pushing on the hazard switch and turn on the turn signal. If it work the hazard switch is bad.
Old Apr 20, 2016 | 03:40 PM
Vanover's Avatar
Vanover
Mine did the samething,get new bulbs,pure some coke in the light socket, (it eats the green meanies out) pack the socket with dielectric grease.put back together.this worked for me a year ago,still works fine.old trick I learned for my grandad.
Old Apr 20, 2016 | 04:09 PM
edbutler66's Avatar
edbutler66
PROBLEM SOLVED. Thanks to everyone who contributed. The simplest solution is usually the right one. It was the yellow 2 stage bulb. One was working while the other was burned out. Y'all have taught me far more than I ever thought I needed to know about lights. Thanks for all the help.
Old Apr 20, 2016 | 04:13 PM
Vanover's Avatar
Vanover
Thanks for the up date.i still would pack them with grease,helps keep water out
Old Apr 20, 2016 | 05:43 PM
dadaroo's Avatar
dadaroo
So you confused the DRL with the Parking light??????????
Why would the Parking light be ON??????????????
Mr. Sam
To Turn signal problems
