[Z06] LG header install
Old Apr 17, 2016 | 10:02 PM
curtis59's Avatar
curtis59
7th Gear
Default LG header install
Just installed LG long tube headers on my 03 Z06, everything went well except I can't get the rear most head head bolt in on the drivers side. All other bolts are good and tight, my question is will it make much of a difference if this bolt is missing.
Thank you.
Old Apr 17, 2016 | 10:08 PM
StingrayRebel's Avatar
StingrayRebel
loosen the bolts back up and loosen the midpipe from the collector as well so you can work the header back and forth as needed... it's a tight fit but you need to have all the bolts in place... I get all the bolts started by hand before I tighten anything down
Old Apr 17, 2016 | 10:43 PM
curtis59's Avatar
curtis59
7th Gear
Thank you for the help, looks like I will be unhooking some things and trying to get this last bolt in.
Old Apr 18, 2016 | 01:17 AM
grantv's Avatar
grantv
Yep, best to run them all. Don't want a leak now or down the road.
Old Apr 18, 2016 | 08:24 AM
curtis59's Avatar
curtis59
7th Gear
Thanks for the comment, certainty don't want any exhaust leaks.
Old Apr 18, 2016 | 08:31 PM
curtis59's Avatar
curtis59
7th Gear
Well spent the afternoon unhooking everything and finally got that pesky rear header bolt in, few cut knuckles but worth it knowing I won't have any leaks.
Thanks for the help.
Old Apr 18, 2016 | 08:38 PM
StingrayRebel
awesome... out of curiosity which headers do you have?... my old 1 3/4's from about 6 years ago were pretty easy to get the bolts lined up but I recently swapped to the newer 1 7/8's and they were a booger to get all the bolts in... I'm guessing the newer sets have tighter tolerances on the flanges
Old Apr 18, 2016 | 08:49 PM
curtis59's Avatar
curtis59
7th Gear
They are 1 7/8's and yip they are a bitch to get all the holes lined up.
To LG header install
