Pull Key and Wait 10 Sec.....
Old Apr 18, 2016 | 01:28 PM
MuscatDetroitC5's Avatar
MuscatDetroitC5
Cruising
Default Pull Key and Wait 10 Sec.....
Hi Guys/Gals:
About a month before I put up my C5 for the 2015-16 winter, I received the above message 3 or 4 times. Usually after its been running for a while, I turn it off then back on. I just took it out of storage for the spring, it started right up, I let it run for 30 minutes, took it for 20 minute drive, and turned it off. 30 mins later I started it, it stalled and I received the above message again. I took the key out and it was fine. Any ideas?
Oh yeah, I did install the Steering Column Lock Bypass last summer. Could that have something to do with it? Thanks in advance!
Old Apr 18, 2016 | 01:33 PM
grantv's Avatar
grantv
Originally Posted by MuscatDetroitC5
Hi Guys/Gals:
Let it run for 30 minutes!? Why? Let the oil circulate and go.
OK, back to the main topic, by steering column lock bypass, you mean the LMC5 from Compliance Parts? If not, buy and install.
How's your battery? I'd have it tested.
Old Apr 18, 2016 | 01:56 PM
MuscatDetroitC5
Cruising
Thank you. My C5 is an automatic. I replaced the battery first. After researching it further, the Corvette forum suggested I install the Bypass and the issue was gone. Only 3 months later the 'Pull Key and Wait 10 Secs....." surfaced.
Originally Posted by 8VETTE7
Profile says the car is a 2000 but no indication if it is a manual or automatic. Makes a big difference for CLB installation. If you installed a CLB and you are still getting the messages then you did NOT install it correctly. You need to remove what ever GM has done to your car as a part of the Recall service for the CLB to function correctly.
You should have opted to install an LMC5 rather than the CLB. The LMC5 abandons all factory or recall wiring downstream of the BCM so you don't need to know what was done for the recall service which is different for manual vs automatic.
I would purchase the LMC5 and install it and do the brown wire mod on page 2 of the install instructions and your column lock problems will be permanently gone........
And I completely agree with the previous poster that the MOST COMMON cause of column lock symptoms is a weak or bad battery or loose or corroded battery connections including the one at the starter.... yesnod:
Old Apr 18, 2016 | 03:19 PM
MuscatDetroitC5
Cruising
Thank you VERY much!!!
To Pull Key and Wait 10 Sec.....
