Another tire thread
Old Apr 19, 2016 | 01:21 PM
Alfyjr's Avatar
Alfyjr
Default Another tire thread
Been reading up on multiple tire sizes and just ordered a 18/19 wheel combo but need help with tire size. For sure want to run a 295/30/19 in the back and a 275/35/18 in the front as everyone else does. However the rear tires I have are new only they're 265/40/18. Will these fit on the front or would it be easier selling these off and getting the size I want. Seems like a waste of good tires..
Old Apr 19, 2016 | 02:08 PM
grantv's Avatar
grantv
What he said... plus your final tire choices are under what's recommended also. You should go either 265-35-18 & 295-30-19, or bump the rear to 305-30-19
Old Apr 19, 2016 | 02:25 PM
Alfyjr's Avatar
Alfyjr
Originally Posted by 8VETTE7
If you run the 265/40-18 on the front with a 295/30-19 on the rear you are going to have Traction Control (TC) issues. The overall diameter of the 265/40-18 is 26.6" and the overall diameter of the 295/30-19 is 26.1" so the front tires will be 1/2" larger than the rears. That is backwards for what the C5 needs.
General rule of thumb is that to avoid TC issues the overall diameter of the REAR tire needs to be 1/2" to 1 1/2" larger than the overall diameter of the front tire. Of course you can avoid the TC issues if you put the car in Competitive Driving mode every time you start it. But if you forget, be prepared to TC to step in when you begin to drive........
So basically it would be to bump up the diameter of the rear or make the front diameter smaller?
Old Apr 19, 2016 | 02:27 PM
Alfyjr's Avatar
Alfyjr
Not sure how much 305's would protrude from the side of the car but I don't think they would fit on a 10 inch wide wheel.
Old Apr 19, 2016 | 03:16 PM
grantv's Avatar
grantv
Yep, pushing it. Go 265/295 or 255/285
Old Apr 19, 2016 | 03:44 PM
Alfyjr's Avatar
Alfyjr
That's what I thought, just gonna stick to the first combo lol.
Old Apr 19, 2016 | 03:58 PM
Good choice.
Old Apr 19, 2016 | 04:34 PM
Vanover's Avatar
Vanover
So am I running the wrong tires.i got 245/40/18 on the front and 285/35/19 on the rear?i have no TC problems
Old Apr 19, 2016 | 04:56 PM
Vanover's Avatar
Vanover
245/40-18 overall diameter 25.7" and 285/35-19 overall diameter 26.9" so the delta is 1.2" with the rears being larger. Would not expect TC issues with that combination.
Good y'all hade me scared,throwing all those numbers around like rocket scientist.nout erbudy dat mart.
( Not everybody is that smart) dam public school.
Old Apr 20, 2016 | 12:23 AM
Alfyjr's Avatar
Alfyjr
Looks like i'm going to have to pick up another set of tires then lol. Thank yall.
To Another tire thread
