Climate control ?
Old Apr 30, 2016 | 07:53 PM
Ducati Guy's Avatar
Ducati Guy
Default Climate control ?
With the control set on auto at 70 degrees and outside temp of 58 degrees the system shows the A/C on. Is providing heat but kinda weird that it is indicating A/C. If I go to manual I can get rid of the A/C. But in auto the A/C shows as on.
Old Apr 30, 2016 | 10:55 PM
Ducati Guy's Avatar
Ducati Guy
Originally Posted by 8VETTE7
AC running with the heat on indicates the system is providing a dehumidifying function. This can be useful in keeping the windows from fogging up in wet/cold/rainy conditions.
In your owners manual which I'm sure you have carefully read, it states that "In temperatures above 40 degrees the AC cannot be turned off on defrost and defog mode as it helps remove moisture from the vehicle".
Yes i did read that and many cars do this as you said to remove moisture. However the A/C is on when the air is being directed to the floor only. Not in defrost mode.
Old Apr 30, 2016 | 11:15 PM
Bill Vett's Avatar
Bill Vett
Go into your DIC and go to the hvac section and clear all codes. You should hear the system cycle. Then check the function and see if it's corrected. You had the unit out to do the display and there may be codes that need clearing.
To Climate control ?
