C5 headlights
Old May 11, 2016 | 08:18 PM
bobjim3's Avatar
bobjim3
Default C5 headlights
Took my 1999 out of storage today. Upon start-up, the headlights flip up & turn on. They won't turn off until the car is shut off and doors are locked. that happens about 30 seconds later. Any ideas?
Old May 11, 2016 | 08:37 PM
RoninC5's Avatar
RoninC5
Not enough info but I'll take a guess- see if you have RPO T85. If you do, go to your DIC and turn off Twilight Sentinel... It was an option I believe in 1999 (first year). Hope that helps...?
Old May 11, 2016 | 08:38 PM
Velocity_Vette's Avatar
Velocity_Vette
EDIT: Beaten to it.
The Twilight Sentinel feature is active and needs to be deactivated. Scroll through "Options" on the DIC until you reach "Twilight Sentinel" and confirm it's status is currently "on". Select "off".
Old May 11, 2016 | 08:54 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Old May 11, 2016 | 10:10 PM
bobjim3's Avatar
bobjim3
I do not have the twilight sentinel option.
Old May 12, 2016 | 05:51 AM
dadaroo's Avatar
dadaroo
Sounds like an MF switch issue if the lights are OFF and they still go up.
Mr. Sam
Old May 12, 2016 | 08:41 AM
Have the MF switch checked for proper operation.
Old May 14, 2016 | 08:47 AM
bobjim3's Avatar
bobjim3
I see error code B26;7 on the DIC
bobjim3's Avatar
bobjim3
Error code: B2647
Old May 14, 2016 | 09:07 AM
dadaroo's Avatar
dadaroo
That is a problem with the ambient light sensor. Either an open circuit or a short to ground. Either will cause the BCM to turn the HLs and Park lights ON.
I would guess the circuit is open.
Need any DIY info? Not hard to access it by the dash defroster vent.
Mr. Sam
Old May 14, 2016 | 06:02 PM
bobjim3's Avatar
bobjim3
Mr. Sam
Thanks for your help. I disconnected the battery & reconnected it. Everything now works. Cleared the codes; they have not returned. Go figure...
Old May 14, 2016 | 06:12 PM
LannyL81's Avatar
LannyL81
Simple...the car did not like being in storage....
To C5 headlights
