Strange TPMS problem--need advice
I have the Orange tire pressure sensors in my 2002 coupe that were working fine until I installed a new AGM battery and now the won't re-program. I'm using dual magnets that came out of a microwave that worked when I first had them installed with my new aftermarket wheels from OE Wheels. I even had the dealer try and program them when I was having some other work done and while they now show a number on the DIC they are stuck on 50, 42, 30, and 21 which keeps telling me I have a low RF tire(which I don't). I bought 4 new GM sensors to install but hate the thought of breaking down the beads of the low profile tires and possibly causing damage so I thought I'd reach out to you guys first for a possible solution.
One other thing I'll mention is I was having the C1214 code which meant a possible ECBM problem but it's been 5 weeks and no more codes since installing the new battery.
Thanks for any input.
Likely something else gong on. I suggest that you pull and post ALL your codes including the H or C or HC that follow each 5 character code. If you have never pulled codes here is how:
https://www.youtube.com/watch?v=SviRjIsy9G4
OR
http://www.c5forum.com/ayc/dtcdic.php
Chances are if the key fob is still working, the receiver is still working too and not your problem with the TPMS sensors.
My guess is something with the sensors. As stated above, pull all the codes and post them here so people can help to debug it.
The TPMS consist of the RFA module (or Remote Control Door Lock Receiver) and the BCM.. It connects to the BCM thru the serial data buss:
It looks like this and is hidden on the drivers side above the wheel well behind the plastic that encloses the speaker:
The drivers door control module is part of a serial buss, but if there was a problem you would have the no communication codes. Below are some of the common codes when the battery has been disconnected. You may not have all of them.....
60-IPC - Instrument Panel Cluster
B0516 Speedometer Signal Circuit Malfunction
B0521 Tachometer Signal Circuit Malfunction
B1512 DIC Switch 1 Signal Short to GND "FUEL"
B1517 DIC Switch 2 Signal Short to GND "GAGES"
B1522 DIC Switch 3 Signal Short to GND "TRIP"
B1527 DIC Switch 4 Signal Short to GND "OPTIONS"
B1532 DIC Switch 5 Signal Short to GND "E/M"
B1537 DIC Switch 6 Signal Short to GND "RESET"
B1542 Oil Temperature Circuit Short to GND
B1543 Oil Temperature Circuit Open
U1016 Loss of Communications with PCM
U1040 Loss of Communications with TCS
U1056 Loss of Communications with RTD
U1064 Loss of Communications with BCM
U1128 Loss of Communications with Radio
U1153 Loss of Communications with HVAC
U1160 Loss of Communications with LDCM
U1161 Loss of Communications with RDCM
U1166 Loss of Communications with SCM
U1176 Loss of Communications with RFA
U1255 Serial Data Line Malfunction
80-Radio - Radio Not Found
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
U1096 Loss of Communications with IPC
A0-LDCM - Left Door Control Module
B2202 Left Window Up Switch Fault
B2204 Left Window Down Switch Fault
B2206 Right Window Up Switch Fault
B2208 Right Window Down Switch Fault
B2222 LT Mirror Select Switch Fault
B2224 RT Mirror Select Switch Fault
B2226 Mirror Right Switch Fault
B2228 Mirror Left Switch Fault
B2232 Mirror Up Switch Fault
B2234 Mirror Down Switch Fault
B2236 Left Door Lock Switch Fault
B2238 Left Door UnLock Switch Fault
B2242 Memory 1 Switch Fault
B2244 Memory 2 Switch Fault
B2252 Key Cylinder Switch Fault
B2262 Horizontal Position Sensor Fit
B2264 Vertical Position Sensor Fault
B2272 Left Mirror Motor Fault
B2274 Window Motor Fault
B2276 Door Lock Motor/Mirror Heater Fit
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2286 +5V Reference Fault
A1-RDCM - Right Door Control Module
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
B2275 Window Motor Fault
B2277 Door Lock Motor/Mirror Heater Fit
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2287 +5V Reference Fault
B0-RFA - Remote Function Actuation
B0605 Receiver Internal Memory Malfunction
B2805 No Transmitters Programmed
C2100 Left Front TPM Sensor Malfunction
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
C2120 TPM System Malfunction (No Sensors Received)
C2121 TPM System Programming Malfunction (No Sensors Programmed)
U1000 Loss of Communication Undetermined
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
for a few minutes and that cleared out all the info on the sensors(each one is now blank-no xxx's) and at least I don't have the low front tire message anymore. I've decided to just leave it as is and keep an eye on my tire pressure the old fashion way just like my other three cars.
Thanks for the replies but this one is a real mystery.
Is that your car in the pic? I am wondering because I see the car in the pic has interior insulation, and I have noticed my TPMS in the front seem to be acting up since I put my insulation in last spring. I'm wondering if the sensors are dying or if there is some sort of interference due to the metallic coating on the insulation.
