Audio System
Old May 18, 2016 | 12:29 PM
Harold97's Avatar
Harold97
Default Audio System
I have a 1997 with the Bose system the rear speakers do not work where can I check this at
Old May 18, 2016 | 12:44 PM
grantv's Avatar
grantv
Safe to assume you adjusted the front / rear balance?
Old May 18, 2016 | 05:01 PM
Harold97's Avatar
Harold97
Default audio system
[QUOTE=grantv;1592240799]Safe to assume you adjusted the front / rear balance?[
Yes, that was the first thing. I just wanted to make sure nothing was lose anywhere before the radio comes out.
Old May 19, 2016 | 06:11 AM
Try posting your question in the Audio/Electronics section - it's listed under the General Corvette area when you click on the Forums tab at the top of the page.
Old May 19, 2016 | 12:27 PM
dadaroo's Avatar
dadaroo
You pulling the radio before any diagnostics?
Mr. Sam
Old May 19, 2016 | 10:57 PM
Milamo's Avatar
Milamo
The screen covers pop right off, start from the bottom and pry gently. I just replaced mine last weekend with kickers, also installed an amp, sub woofer, tweeters and new deck...sounds frickin awesome. Next week or 2 will be replacing the door speakers.
To Audio System
