Wheel Help
Old May 21, 2016 | 08:56 AM
mwbgtb's Avatar
mwbgtb
Default Wheel Help
Hi guys,
I'm a new corvette owner (previous Shelby owner) and purchased a 2000 coupe that needs new wheels.
A local guy has a set of C7 Z51 2015 wheels/tires for sale and they are in great shape.
Front245/35-19 with 56 offset
Rear 285/30-20 with 79 offset
My question for you guys is will these fit my car without any problems rubbing?
Old May 21, 2016 | 10:59 AM
mwbgtb's Avatar
mwbgtb
Originally Posted by 8VETTE7
C6 and C7 wheels have the same offset specifications which are significantly different than the C5 offset specificatons so the same issues that exist putting C6 wheels on a C5 apply to putting C7 wheels on a C5.
Here is a table of wheel specs:
Backspace/offset dimensions are as follows:
C5 (coupe/vert):
Front 17x8.5", 58mm offset = 7.03" backspace
Rear 18x9.5" 65mm offset = 7.81" backspace
C5 Z06:
Front 17x9.5", 54mm offset = 7.38" backspace
Rear 18x10.5", 58mm offset = 8.03" backspace
C6 (coupe/vert):
Front 18x8.5", 56mm offset = 6.95" backspace
Rear 19x10", 79mm offset = 8.61" backspace
C6 Z06 and C6 GrandSport:
Front 18x9.5", 40mm offset = 7.22" backspace
Rear 19x12", 59mm offset = 8.82" backspace
C5 and C6 wheel circle:
5 on 4.75" (120.65MM)
Center hub dia. 70.3mm
Specifically to answer your question , you will likely need a 1/4" spacer on the rear wheels to just to keep them from rubbing the inner wheel well lining. Front wheels will work OK. Even with the 1/4" spacer (max you can run without installing longer studs) the wheels will appear sunk into the wheel wells. If you are OK with that appearance go for it. If you want the wheels to be flush or near flush to the rear fender as many C5 owners with C6 wheels want, then you will need about a 1" wheel adapter. Wheel adapters bolt to the factory studs and then have their own studs that the wheel mounts to.
Thanks 8Vette7 for the info, it sounds like I just need to find some wheels that will fit the C5 without any spacers .
Old May 21, 2016 | 08:56 PM
If you like that style wheel, you might want to look into a set of reproduction C7 Z51 wheels that have the proper C5 offset and are in the 17/18 diameter if you don't want to have to buy new tires.
Old May 21, 2016 | 10:09 PM
mwbgtb's Avatar
mwbgtb
Thanks VettemanJack, I will look into those
Old May 21, 2016 | 10:16 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I have the Black reproduction's (ordered chrome, long story) Welcome to the C 5 forum and congrats on your buy !!!!
Old May 22, 2016 | 08:21 AM
mwbgtb's Avatar
mwbgtb
Thanks Akapounder
To Wheel Help
