key Flob doesn't work
Old Jun 3, 2016 | 01:14 PM
sixbytwo's Avatar
sixbytwo
Default key Flob doesn't work
Replaced battery....nothing happens
Old Jun 3, 2016 | 01:17 PM
buckeye1872's Avatar
buckeye1872
Try to relearn fob. Instructions in this post. https://www.corvetteforum.com/forums...m-key-fob.html.
Old Jun 3, 2016 | 01:19 PM
nsogiba's Avatar
nsogiba
You need to "retrain" the fobs so that they communicate with the car. Easy to do.
https://www.corvetteforum.com/forums...post1576169585
Old Jun 3, 2016 | 01:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
Old Jun 3, 2016 | 02:18 PM
Shakeydeal's Avatar
Shakeydeal
What's a key flob?
Shakey
Old Jun 3, 2016 | 02:52 PM
Murray Anderson's Avatar
Murray Anderson
Originally Posted by Shakeydeal
What's a key flob?
Shakey
It's why C5's are priced as much as C6's.
They changed to the common FOB in '05
The
Old Jun 3, 2016 | 04:32 PM
mrlmd's Avatar
mrlmd
The Owners Manual is a wonderful thing, it should be read more often.
Old Jun 3, 2016 | 04:44 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
Let's see... Changing Target Coordinates, Day HUD Settings, ah... Here we go. Ejection!
Old Jun 3, 2016 | 08:06 PM
Hopefully retraining the FOB to the car will do the trick. If it still doesn't work, does your tire pressure sensors work?
Old Jun 7, 2016 | 03:22 PM
t1fudd's Avatar
t1fudd
St. Jude Donor '17
Is there a difference in fob's for a 2000 and a 2001?
Old Jun 7, 2016 | 07:41 PM
73Corvette's Avatar
73Corvette
97-2000 are FLOBs
01-2004 are FOBs
The FLOBs and FOBs CAN NOT be swapped...except you can FLOB for FLOB but NOT FLOB or FOB...or FOB FOR FOB but NOT FOB for FLOB...
Old Jun 7, 2016 | 10:30 PM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
I like it!!!
Easier to follow than my explanation!!!!!!!
sorry Chuck I just didn't know what INTERCHANGABILITY meant tooooo many letters for my pea brain.
Old Jun 7, 2016 | 11:01 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Love it!!!
Old Jun 7, 2016 | 11:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Brother................. Thank you for serving!
Bill
Old Jun 8, 2016 | 10:06 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Old Jun 8, 2016 | 10:08 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Originally Posted by 73Corvette
97-2000 are FLOBs
01-2004 are FOBs
Old Jun 18, 2016 | 05:17 PM
calguy's Avatar
calguy
Once you have the cover apart, check the clamp that holds the battery in place.
Look closely and you will see the clamp has two small solder points (one on either side of the clamp.)
If these are broken, the fob will not work.
I know, and upon investigation, that was the case with my key fob.
Once I soldered them again, it works fine.
Bob.
To key Flob doesn't work
