[Z06] Alignment experts step in...
Old Jun 8, 2016 | 03:12 PM
95vettski's Avatar
95vettski
Default Alignment experts step in...
Looking for suggestions on how to setup my alignment to maximize straight line traction without compromising handleing.
2004 Z06
LG coilovers
Stock 17" wheels up front
18" wheels in back with 345/35/18 drag radials
Was thinking 0 camber in the back but sure on the toe?
Any suggestions?
Old Jun 9, 2016 | 09:56 AM
Solofast's Avatar
Solofast
Going to zero camber already compromises handling but that is what you want if you want to optimize straight line acceleration.
If you want a drag car jack the ride height up so that you get more weight transfer, you'll be much faster out of the hole.
A bit of toe in in the back is necessary for stability. If you don't toe it in a bit you could get really unstable when you lift of the gas after the finish lights. I'd recommend at least 1/8 of an inch of total toe in as a bare minimum in the back. Any less and the car can get loose on the overrun.
Old Jun 9, 2016 | 09:46 PM
FASTFATBOY's Avatar
FASTFATBOY
Stock alignment
Old Jun 11, 2016 | 06:41 PM
95vettski's Avatar
95vettski
So this is what I ended up with. Not quite the zero camber I was suggesting, but with fresh rubber I have some traction lol.
The rear had more camber previously and the toe was really off.
Not sure how much the alignment contributed, but it does seem to ride better. The front seems like it pulls ever so slightly requiring slight steering correction, but I think it has more to do with the road.
Your thoughts with these settings?
To Alignment experts step in...
