Need help chasing a severe misfire. Engine misfires when cold started. Misfire is so bad it shakes the car when under power. Also will pop from time to time. As the car comes up to operating temperature the skip will lessen and eventually go away. It is most noticeable when under power and the engine is luging just a little. This skip is serious like it is only running on 5 or 6 cylinders.
NO Check engine light and NO codes????????????
2000 A4 with 38500 miles
Ported & polished throttle body
Z06 airbox with K&N filter
Z06/LS6 intake manifold
Kooks long tubes with X pipe and Corsa Pace cars
Need help on where to start looking.
Had a similar problem with my /76 Ford pickup. Took the mechanic hours to find, it was a loose wire in the distributor that maintained contact most of the time. Sounds like you have a loose connection somewhere. HTH.
