1997 C5 with A/C issue
1.) Clear the DIC's and be sure your ac and car is off
2.) Go to your passenger side floor board
3.) Find the fuse box access panel
4.) Pull the top of the panel out a little to break the top velcro strips loose
5.) Pick up on the bottom of the panel and it should come free
6.) Locate Fuse # 27, it's the 10 amp fuse
7.) Pull it
8.) Wait a FULL 60 seconds
9.) Put back in the # 27 fuse (be sure its good)
10.) Put the bottom of the fuse box access panel in first
11.) Push the top of the fuse box access panel to secure
12.) CRANK her up
13.) Car will recalibrate the actuator, about a minute
IF the actuator gears are stripped then you have to repair or replace them...
