Help Finding ABS/Traction Control Threads
Old Jun 12, 2016 | 01:57 PM
Vette10R's Avatar
Vette10R
Default Help Finding ABS/Traction Control Threads
Hi guys I have a 1999 coupe and I have been having issues with the abs and traction control not working. Every time I start the car it says service ABS service Traction service tire pressure sensors. It's getting very annoying and I would like to fix it or bypass it of possible.
I believe I have read a few threads in the past about the subject but can't seem to find them? Can anyone point me in the right direction or give me advice on this please?
Thanks Eric
Old Jun 12, 2016 | 02:33 PM
RedRiderZR1's Avatar
RedRiderZR1
Assuming you found those threads on corvetteforum, put this into a google search
c5 corvette service ABS service Traction service tire pressure sensors site:corvetteforum.com
It will bring up a lot of threads on those subjects on corvetteforum. Does a way better job than using the search feature on the forum.
Hope it is a ground issue or something like it. If its a bad EBCM only option is a used one. As for bypassing it, it can't be done. When mine went out in my 99, I just found a good used one. So hopefully its not a bad EBCM for you. And the used ones are quite expensive.
Old Jun 12, 2016 | 03:19 PM
Vette10R's Avatar
Vette10R
Thank you I will give that a shot.
To Help Finding ABS/Traction Control Threads
