under hood pad
Old Jun 16, 2016 | 08:17 PM
SSTG's Avatar
SSTG
Originally Posted by Rexde1
I was going to take mine off and paint it but it looks delaminated around the edges so I did nothing yet.
Mine is delaminating also.
Does anyone know where a new one can be purchased?
Old Jun 16, 2016 | 08:31 PM
73Corvette's Avatar
73Corvette
That is a dealership item... just a little over $100 and worth it because of the shipping issues... remove the old one and have the plastic retainers ready when you go to the dealership and just install it there
Old Jun 16, 2016 | 10:10 PM
not2old's Avatar
not2old
Default way over $100 here
My 2 local dealers quoted $200.92 and $186.56. I'm going to attempt a diy repair for my delaminating liner this weekend. I'll post a picture thread if successful.
Old Jun 16, 2016 | 10:19 PM
El original's Avatar
El original
Originally Posted by SaxyVette
Talked to a guy he said the factory pad has fire retardant in it, designed to save the hood and smother the motor in the event of a blaze. Also he said even the factory pins are important as they melt quick to drop the pad...
Well I don't know if this is a true story or not ??
My under hood pad is ancient and the light socket is shot but at least it's intact with factory pins.
Well if it is a urban legend it is well thought out. I can't see why it would not function as mentioned. Completely possible. I will leave mine as it is complete with water stains just incase!
Old Jun 16, 2016 | 11:02 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I am fairly certain it's only function is sound or heat control !!!! (or both)
Old Jun 17, 2016 | 11:06 PM
jjaaam's Avatar
jjaaam
3M spray adhesive would be your best friend in this case...trust me. Mine looks ALMOST new after using a little of that and some tire foam to clean it up.
Not perfect mind you...but good enough for me. Looks a LOT better than it did.
Old Jun 18, 2016 | 02:12 AM
striper's Avatar
striper
I sprayed mine with flat black BBQ paint. Makes it look good and last longer and provides a good base for some airbrush artwork.
Old Jun 18, 2016 | 06:12 AM
JohnnyDee's Avatar
JohnnyDee
2023 C7 of the Year Finalist - Modified
2019 C5 of Year Finalist (performance mods)
2017 C5 of the Year Finalist
Spray it with tire foam and let it dry. Works great. I did mine in place, just covered the engine and fenders with plastic.
