under hood pad
Old Jun 15, 2016 | 02:49 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Default under hood pad
Have any of you cleared your under hood pad ??? My dirt road is starting to get mine a lighter shade !!!!! not acceptable Also if you have what did you use ??? I'm thinking urethane ????
Old Jun 15, 2016 | 03:03 PM
Verrückt ZR1's Avatar
Verrückt ZR1
I took mine off a couple months ago with the intention of cleaning it. It's still sitting in the corner of the garage.
Old Jun 15, 2016 | 03:09 PM
v8srfun's Avatar
v8srfun
Mine has a hole in it I am planning on just removing it permanently
Old Jun 15, 2016 | 03:10 PM
Keev1414's Avatar
Keev1414
2017 C5 of the Year Finalist
Took mine off 2 years ago. No problems.
Old Jun 15, 2016 | 03:11 PM
Mitch45's Avatar
Mitch45
Mine had developed a white ring around the edges . Sprayed it with No Touch tire cleaner , next day it looked like new . That stuff works great on plastic too , sprayed the engine compartment and the wheel wells . I see that it also comes in wet look now .
Old Jun 15, 2016 | 03:46 PM
Macleod52's Avatar
Macleod52
On my old Grand Am the hood pad was getting white due to salt and stuff from the road. I hosed it off to clean it good and used some black spray paint. It worked pretty well but I'm not sure if that's the route you'd want to take.
Old Jun 15, 2016 | 03:49 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
I've used Meguires D101 All Purpose Cleaner on mine with great reults.
Old Jun 15, 2016 | 03:52 PM
73Corvette's Avatar
73Corvette
Leaf blower when I first get home... then gently use shop vac with a soft brush to finish cleaning...
Old Jun 15, 2016 | 04:16 PM
Fast Cars & Horses's Avatar
Fast Cars & Horses
Mine is off now. I sprayed it with tire foam and let it sit, then gently wiped with a wet sponge and let it dry and then spray painted it with high heat flat black paint. I'm about 1/2 done painting the C5 emblem and it looks good so far. It's very time consuming to do it right....
Old Jun 15, 2016 | 04:29 PM
JR-01's Avatar
JR-01
Sprayed mine with Simple Green then wiped off with wet rag.
Old Jun 15, 2016 | 06:52 PM
v8srfun's Avatar
v8srfun
Simple green may be the best degreaser ever invented love the stuff
Old Jun 15, 2016 | 07:09 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
I use this stuff all the time as well on various surfaces
Old Jun 15, 2016 | 08:37 PM
Clancy209's Avatar
Clancy209
Clean first then Use BBQ black hi temp
Old Jun 15, 2016 | 09:35 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I have already cleaned it and resprayed with fabric black looked like new ,I just don't want to have to do that all the time.
Old Jun 15, 2016 | 09:37 PM
JR-01's Avatar
JR-01
Oh.
Old Jun 15, 2016 | 10:57 PM
jdvann's Avatar
jdvann
Can you spray clear on it on the back side to see what happens first?
Old Jun 15, 2016 | 11:33 PM
73Corvette's Avatar
73Corvette
Maybe treat it with some water proofing spray... like the old tent water proofing stuff we used to use... whatever you find that works will be awesome cause then I can do mine too
To under hood pad
Old Jun 16, 2016 | 01:30 AM
This might give you some ideas.
File Type: doc
Old Jun 16, 2016 | 02:14 PM
SaxyVette's Avatar
SaxyVette
Talked to a guy he said the factory pad has fire retardant in it, designed to save the hood and smother the motor in the event of a blaze. Also he said even the factory pins are important as they melt quick to drop the pad...
Well I don't know if this is a true story or not ??
My under hood pad is ancient and the light socket is shot but at least it's intact with factory pins.
Old Jun 16, 2016 | 05:21 PM
Rexde1's Avatar
Rexde1
I was going to take mine off and paint it but it looks delaminated around the edges so I did nothing yet.
