How do I get my radio code?
Old Jun 18, 2016 | 12:56 AM
Ducati Guy's Avatar
Ducati Guy
Default How do I get my radio code?
In anticipation of one day removing my battery or having it go dead for some reason I want to have my radio security code handy.
How / where do i get he code?
Old Jun 18, 2016 | 09:26 AM
BSenzina's Avatar
BSenzina
I didnt know there was such an animal. I have a 98 vert. Do i have this feature, and if so how do I check if its enabled so I can turn it off????
Old Jun 18, 2016 | 09:45 AM
You will know if it is enabled if there is a red light that flashes on the radio when the ignition is off. It is just a small light I believe next to the volume button (trying to go by memory since I am not near my car right now to look at the radio).
Old Jun 18, 2016 | 09:59 AM
RoninC5's Avatar
RoninC5
You are correct sir... In fact, I should just disable mine. It locked when I installed the LMC5.. Good thing the code was written in the owners manual....
Old Jun 18, 2016 | 10:42 AM
GCG's Avatar
GCG
In case you need to unlock your C5 radio after "LOC" has been activated: click here for step-by-step instructions.
Ducati Guy's Avatar
Ducati Guy
Just the info I was looking for. You guys rock!!! No flashing light. So I am good. The main reason for the question was that fact that I will be installing the steering lock 'thingy' soon and figured that i would be told to disconnect the battery.
Old Jun 18, 2016 | 11:11 AM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Thanks for the info
To How do I get my radio code?
