I just received a set of 4 URO Jacking pucks for my C5.
I have only tried to install on the drivers side so far. They snap into place but fit very loosely and would probably fall out under normal driving.
I like the design and how they will work so I am looking to use some type of adhesive to have them not only snapped into place but also glued into place.
Anyone have a suggestion on what adhesive to purchase?
Anyone else ran into this issue?
But IF...I would just use a silicone to adhere them... but I use silicone for everything...
That's what I did. Just a dab to keep them from rattling and they still pop off if needed. Have not had a problem in 4 years. They are nice. The car is always ready to jack up. Used them just this morning.
Originally Posted by thisMSGgood4me
Why glue them into the slots? What if you needed to use those slots to tie the vehicle down on a trailer? If you're worried at all about them falling out, then just don't leave them in the slots. They are serving no purpose installed in the slots if the vehicle isn't being lifted. Store them in one of the compartments in the rear and pull them out and install them when they're needed. It's really that simple.
BTW, I use a set of BMW jacking pucks on my car - they snap in place and have been on the car for nearly seven years. Not one problem with them coming off.
