Tire recommendations
Old Jul 2, 2016 | 08:26 PM
friou's Avatar
friou
Nitto 555's, like 'em! Seems to do everything pretty well. Take care!
Old Jul 2, 2016 | 11:09 PM
Fatbob's Avatar
Fatbob
I just put BF Goodrich comp 2 AS on, replacing the runflats. These tires make it like a new car. The overwhelming noise from the old hard runflats was gone. They also have much more grip. The reason I bought them was the excellent rating that Tire Rack gave them.
Old Jul 3, 2016 | 08:39 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Nitto NT-05 in 275/295
Old Jul 3, 2016 | 08:13 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
- I just put these on mine about 5,000 miles ago. I replaced Michelin Pilot Sport run flats, and the BF Goodrich tires are awesome. Also you might note that Michelin has spent a good deal of engineering on the new BF Goodrich Comp2 AS and it is essentially the same quality as the Super Sport AS.
Old Jul 9, 2016 | 12:40 AM
MagRedGeoff's Avatar
MagRedGeoff
Just purchased Michelin Pilot Sport A/S 3 +. Have only driven on them for a couple days. They are quiet and seem real grippy. Very happy so far. My last set was Michelin A/S plus with 48,000 miles on them. I liked them but experienced sidewall cracking at tread line. Trying out the non run flats this time.
Old Jul 9, 2016 | 07:55 AM
chasboy's Avatar
chasboy
Oldtimer
Originally Posted by Mike98SilVert
I have the BF Goodrich g-Force Sport Comp-2's in stock sizes. I bought them from Discount tire direct .com for around $650 shipped during a special event back in March. They have very good dry and wet traction. I also recommend Nitto 555 Extreme and Kumho Ecsta from previous experience.
I have the same, from my local tire dealer. Excellent tires, great tread pattern, non runflat. 1/2 the price of the Michelin or Goodyear.
Old Jul 9, 2016 | 08:15 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by jackthelad
In the last 10 years or so, I have had a number of punctures - mostly slow leaks which I fixed with plugs, but a couple of total failures (on my other car) due to potholes in winter which were filled with snow, so I didn't see them. My previous set of tires had probably 2-3 plugs in each tire by the time they were done. Mostly nails and screws which I put down to visiting Lowes, HD, etc., though the last one I know I picked up at the local Autozone - it was an automotive trim screw and the pressure started to drop on my way home.
I regularly drive on some scary roads - I81 and I70, both of which have become cowboy truckers' racetracks, so I stick with r/f's so I don't have to try to deal with a flat on the shoulder, with the risk of being wiped out that entails. May sound dramatic, but in the last 3 weeks there have been three fatals on I81 within 10 miles of my exit.
Good advice!
Getting a flat, and having to drive a couple of miles on it (slowly) to get to the next exit of the Interstate, is one thing. Even if you destroy the tire, but have a spare to put on, you'll survive. Without a spare, like the Corvette, you're stuck....
Old Jul 9, 2016 | 09:04 AM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
I run the run flat michelins on one and the continentals on another. The continentals are much much quieter and smoother. I will ditch the run flats when they wear out.
Old Jul 9, 2016 | 11:40 AM
Mike98SilVert's Avatar
Mike98SilVert
Great dry and wet reviews. There are no compromises with these tires according to everything I read so I chose them over the Nitto 555 's I had been planning to buy. They have a great tread pattern plus the tread width is wider than most other stock replacement tires. I checked my receipt and I actually paid only $606.60 shipped to my installer. Check for current rebates.
