[Z06] ZIP TIE mod done
Old Jul 12, 2016 | 08:46 AM
dylans's Avatar
dylans
Default ZIP TIE mod done
I did the zip tie mod last night. I can say to anyone thinking of doing this, it's super easy! Took me about 30 min total. This is my first mod, and I'm just so proud right now .
The only problem I ran into was getting the MAF plug off of the sensor. You have to remove the gray tab by prying the black locking tab up slightly while working the gray tab out from underneath of it. Be careful, my gray tab shot off into the front bumper. I was able to recover it once the air box was out.
After removing the gray tab, take the same black tab you had to pry up, and press it down while pulling on the plug.
Pop off the two front rubber mounts, the two upper rubber mounts and loosen from throttle body. DONE!
I bought some 18 inch black zips from Lowe's. They're as fat as the stock metal straps your'e going to remove. Really heavy duty. I wish I had pictures of how I made the new straps because I think I worked out something very clever.
If anyone is really interested in how I worked the ties, I may be able to snap some pics or try to explain.
I used the stock filter clamps to retain the ease of filter replacement. Got the tension just where I wanted it and reinstalled. I left about 6 inches of extra tie for now in case I have to make adjustments to the tension.
I took it for a spin for a few miles, and I really did notice a difference in acceleration and speed. WOW. Like a big difference. After I got it home I did the PCM relearn procedure just for piece of mind.
Procedure here, by C5XTASY: https://www.corvetteforum.com/forums...ull-fuses.html
Front hood seal is on it's way to me, and I'll be buying a k&n filter to replace the stock paper one. Both for protection against excess water, dirt and dust.
I'll update after a few days of driving to really let you all know how it performs.
Old Jul 12, 2016 | 10:39 AM
wrkdWS6's Avatar
wrkdWS6
Nice job, zip-tie is a nice free mod to get your feet wet.
If you want to try another free mod you could perform the tb bypass. I have no idea if it makes a difference or not but I don't see how it could hurt.
Old Jul 12, 2016 | 11:02 AM
dylans's Avatar
dylans
What's the intent of that one?
Old Jul 12, 2016 | 11:20 AM
wrkdWS6's Avatar
wrkdWS6
From the factory, coolant passes through the throttle body. It's my understanding that this feature was employed to aid cold starts in freezing temps which potentially could prevent the tb blade from getting stuck/frozen. It seems reasonable that this feature could potentially increase the temperature of the incoming air into the intake manifold, although air is moving pretty darn quick when you have her opened up so who knows. Anyways, many people simply bypass the throttle body altogether. I can attest that the throttle body will be cooler by the touch than prior to the bypass but I have no measurable performance data to back up the effectiveness of the mod. However, it is relatively free (maybe a couple bucks for a hose barb and clamps) so I figured why not because I like to tinker. Done it on my LT1 about 10 years ago too.
Here's a link with pics:
http://www.corvettedreams.com/bypass.htm
Old Jul 12, 2016 | 03:03 PM
MY03C5Z's Avatar
MY03C5Z
Yep thats a great free mod. Did it to mine the day after I got it . When I dynoed mine I only had that and the tb bypass and it made 363rwhp.
Old Jul 13, 2016 | 12:02 PM
dylans's Avatar
dylans
I decided to skip the tb bypass. I did the idle relearn after the zip tie mod, but havent driven it much since. How long until it really learns the new flow?
Old Jul 13, 2016 | 12:57 PM
wrkdWS6's Avatar
wrkdWS6
I just also did the side bolster mod. I'm 5'11" and 150. The seats hold me now. Nice and tight! I recommend the mod to anyone who needs a tighter seat.
Never heard of that one, I'll have to check it out. I'm 5'10 150 so I'll take all the side bolster I can get haha. Something else you could do...skip shift eliminator. It's not free, about $20, but gets rid of that annoying 1-4 skip shift feature. I had mine tuned out in the computer so I'm gonna pull off my eliminator and sell it soon but I definitely recommend.
Old Jul 13, 2016 | 03:09 PM
MY03C5Z's Avatar
MY03C5Z
Not sure what the idle relearn is, unless thats just disconnecting the battery to clear some settings out of the pcm. I had heard of the seat bolster mod but never did that, Ill have to when I get a chance. 5'11 170 here.
Old Jul 13, 2016 | 03:19 PM
dylans's Avatar
dylans
I followed a certain procedure that involved pulling number 16 and number 23 fuse from the engine bay fuse block. A series of starts and idling and shutting down after. I may not have needed to do it, but figured it couldn't hurt.
Old Jul 13, 2016 | 04:13 PM
wrkdWS6's Avatar
wrkdWS6
Thank you for the post on the seat bolster! And regarding the 1-4 skip shift, you will encounter that lovely feature soon enough haha
Old Jul 13, 2016 | 06:12 PM
dylans's Avatar
dylans
When that time comes, I'll remember who warned me. Thanks!
Old Jul 13, 2016 | 09:38 PM
furious427's Avatar
furious427
Thanks for posting about the seat trick, gonna try that tomorrow.
Old Jul 13, 2016 | 10:49 PM
CalF's Avatar
CalF
I did the seat mod on mine and it made a big difference for me at 5' 10" and 165 lbs.I did take the seat out as it made it easier for me.I did NOT do the passenger seat as the wife sat in the modded seat and didn't care for the fit.She is 5'8" 150 lbs.You might want to be mindful of who your passengers are as the modded seat is snug for women with some curves.
Old Jul 20, 2016 | 08:22 PM
jallen355's Avatar
jallen355
Old Jul 21, 2016 | 05:05 PM
danh52's Avatar
danh52
So what's the "zip tie mod"?
Old Jul 21, 2016 | 05:13 PM
MY03C5Z's Avatar
MY03C5Z
Removing the cover from the stock air intake box and securing the filter with zip ties.
Old Jul 21, 2016 | 05:14 PM
dylans's Avatar
dylans
You take the top of the air box off, and to hold pressure on the filter frame, you use large zip ties. Results are a fully open air filter. Much better flow. Many people show positive dyno results. Whp and wtq gains.
I bought a front hood seal to add more dirt and water protection to the exposed filter. Though the new set up really is the same amount of exposure as a cai kit. I will also purchase a k&n for beter flow and protection. Easy. Done in 20 min.
I did the zip ties a little differently so I could use the stock frame clips so I can still change filters easily.
Old Jun 25, 2018 | 11:01 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
On a related note, would a smooth silicone coupler between the air bridge and throttle body flow more air than the stock accordion-style coupler which creates air turbulence?
I'm also curious on which size silicone coupler is needed if this holds true.
EDIT/UPDATE: Just to follow up on my post here- based on some reading on other technical forums, the accordion hose is needed (versus a smooth hose) to create air turbulence. Apparently turbulent air mixed better with fuel. I guess there's a reason that even modern day Ferrari engines (like the 458) still use an accordion-style hose/coupler leading up to the throttle body.
Old Jun 25, 2018 | 11:11 AM
jjc508520's Avatar
jjc508520
https://www.corvetteforum.com/forums...a-success.html
To ZIP TIE mod done
