Running lights
Old Jul 13, 2016 | 09:14 AM
1978vett's Avatar
1978vett
Default Running lights
Is there a way to turn off the running lights ? 04 Convertible .. Thanks
Old Jul 13, 2016 | 11:55 AM
rrwirsi's Avatar
rrwirsi
I have been told that the Running Lights are controlled by fuse #2 in the engine compartment. If you pull parking brake one click, running lights go off. Personally, because of the low stance of the Vette, I prefer the running lights on. But your choice.
sbark's Avatar
sbark
1st Gear
Default Day time running lights
To turn off running lights try pulling #2 fuse under hood. This should turn off lights but will also cancel your lights flashing when use use your key fob to lock and unlock car.
Old Jul 13, 2016 | 12:28 PM
1978vett's Avatar
1978vett
Thanks for the info. guys.
Old Jul 13, 2016 | 01:00 PM
Carl Timonen's Avatar
Carl Timonen
When you remove the fuse, your fog lights will still flash when using the fob to lock.
To Running lights
