Multiple issues after brass gear install // HELP PLEASE
Old Jul 15, 2016 | 02:35 PM
memario1214's Avatar
memario1214
Default Multiple issues after brass gear install // HELP PLEASE
Well I got the oh so common spinning of the gears on one side when I would close my headlights leading them to come up with the parking lights, not go down right all of the time, etc.
I ordered the brass gear replacement, did the conversion on both sides, and reinstalled. Here is what I am now left with...
1) Headlights still come up when the stalk is turned one click aka. parking lights.
2) Headlights will not go down, and do not even make an attempt to go down. The is no noise to indicate that they are trying to do so.
3) The lights themselves no longer come on. Turning the switch to the second click to fire up the headlights does nothing, makes no sound, etc.
I have run around and checked fuses and everything seems to be in the right place. What am I missing? Any help is GREATLY appreciated.
Old Jul 15, 2016 | 03:39 PM
memario1214
OP edited and also probably the source of all of my issues... when I open the drivers door regardless of the position of the the stalk, I get the door chime as though I forgot to turn my lights off. This has to be a major piece of it.
Old Jul 15, 2016 | 03:50 PM
vetintheblood's Avatar
vetintheblood
From: Beavercreek Ohio Currently own: 1958 Silver Blue Corvette & 1969 Riverside Gold Corvette Coupe
2025 C1 of the Year - Unmodified Finalist
Couple of thoughts...
Did u open the headlight doors manually?
Do you have the Twilight option?
Old Jul 15, 2016 | 03:53 PM
stingray76l82's Avatar
stingray76l82
Are the plugged in right? Just a thought
Old Jul 15, 2016 | 04:26 PM
memario1214
Yeah everything appears to be wired up fine. No twilight option. Check this out.
https://youtu.be/7q25ETKPal8
Old Jul 15, 2016 | 06:42 PM
memario1214
HUZZAH! Tons of troubleshooting led me to discover that I had NOT installed the low beam plugs correctly. The Radioflyer ACA plugs are meant to be installed backwards. I came to that epiphany after hours of messing with a multimeter and eliminating variables... but either way. All better!
Old Jul 15, 2016 | 06:47 PM
73Corvette's Avatar
73Corvette
Glad you saw the light... Thanks for posting your outcome many don't and it's kinda frustrating when there is no closure
Old Jul 15, 2016 | 07:17 PM
memario1214
Absolutely! I posted for that exact reason as I always seek closure on the threads that have issues similar to mine. I thought I was really running down quite the rabbit hole based on the behavior of the lights when I filmed them. Amazing that a simple flip was the solution.
Old Jul 15, 2016 | 07:20 PM
Black 03 Z06's Avatar
Black 03 Z06
Glad you got it sorted out. I kept the Radio Flyer installation instructions in the car just in case I every had a problem.
Well done, well reported.
To Multiple issues after brass gear install // HELP PLEASE
